Sold/Expired NightLightning Adventure Lighting ~ For serious adventurer
kalkwasser
Asia
New NightLightning IBlaast Adventure Light featuring 3 x 'U' series P-4 SSC® LEDs 240 Lumens each @ 1000ma. Selling with the Li-ion 4.4Ah 14.8V battery & fast smart charger. 475gms. Canadian cells.
Upgraded the cable wrap and premium connector. Stickers, I added myself on the battery pack :D
Purchased at $520. Selling for $500 ship worldwide.
Beam shots, photo by NightLightning
Specification:
Fully upgradeable as the technology advances
High efficiency 19mm Tri optics. 10 deg standard, 25 deg flood available
Replaceable front acrylic plate
Removable mounting bracket
Durable double coated alloy barrel with optimised ventilation
UV stabilised thermal plastic end cap
Stainless fasteners for long life
Sensitive membrane switch
Weather sealed cable entry
Built tough
First to say "I take it, get it"
Cheers!
What is the envisioned or calculated Run Time here? And is this regulated in some way to give some kind of illumination where peak power dies out?
Thanks!!
Thanks!!
Yes, its regulated to give a constant illumination.
Here is a more detail information :thumbsup::
Features-
  • Up to 720 Lumens at full power!
  • The best priced high powered LED portable light on the market
  • 3x SSC P-4 Z-Power LEDs with full switch mode current regulation for maximum run times
  • Upgradeable LED light source. Future proof
  • Precision 19mm optics for a superior spread
  • Edit & choose from 2 or 3 stage dimming. Set your own power levels- all user editable on the fly
  • Multistage fuel gauge that tells you what your battery is doing (Can be disabled) & deep cycle battery protection
  • Day time use flasher modes including SOS
  • Helmet mount comes standard, optional handle bar or cap mount available
  • Runs from any 12V through to 18V battery
For more detail specs, www.nightlightning.co.nz/endurenz%20details.htm
