get-lit
A few years ago I've reviewed the latest lamps with the highest luminance in cd/cm^2 to find one that is capable of the most throw for a new portable mega light. I was most impressed with Ra's Maxablaster with a lamp having a luminance of 170,000 cd/cm^2. But I felt it could be improved because it only produced 4,000 lumen, and almost half that was not utilized because of the reflector required to handle the high amount of UV from that lamp. The reflector absorbed much of the visible light and the visible light it did produce also had poor color rendition. The lamp life lasted only a few hundred hours as well.
Here is a past thread from the last time I considered this a few years back...
http://www.candlepowerforums.com/vb/showthread.php?t=149969
Back then I settled on the Osram XBO 500W/RC OFR lamp with a luminance of 260,000 cd/cm^2 but it soon became unavailable and I gave up for a while to wait for UHP lamps to mature. And now a few years later, we have lots of them for DLP projectors. One lamp series in particular is the Osram P-VIP 100-120/1.0 P22h DLP Lamp with 200,000 cd/cm^2. The lamp would have to be separated from it's reflector to use a high grade 9" reflector and a Thor host. It has excellent color rendition since it's for projectors, and the lamp itself produces roughly a nominal 7,000 lumen. With a lamp life of around 6000 to 8000 hours, it could possibly be doubled to 240 watts and run for 500 hours with a luminance of 400,000 cd/cm^2 and 14,000 lumen. That is the 4 times the luminance of the Osram XBO 7000 Watt! Since it's the luminance that determines the throw potential, this could be one heck of a light. The lamp is only $110.
Anyone have any other considerations?
