It is much harder to see with the NDI -
I first noticed it on the D10 (different reflector - therefore different characteristics) - and then looking harder saw it on the NDI too.
Hold the light on Max about 1 ft away from a plain white surface where one should be able to see the whole of beam including all of the side-spill - now look carefully at the transition/boundary from that creamy/yellow "donut"/corona out to the side-spill see the violet/purplish very faint halo?
(use the -2 stops underexposed shot of the D10 vs. NDI as a guide to where it is)
Like I said it is much easier to see on the D10, and hardly even there on the NDI - so in all practicality it is "not there"
- but it really still is, if you deliberately look for it.....
EDIT to ADD -
another consideration when looking at beamshots is the monitor - most people are probably now using LCD monitors - which tends to make things look cooler and much more blue when compare to real-life.
Why? think about the backlight used on LCD monitors they are mostly CCFL (Cold Cathode Fluorescents).
This is what the
DIYwiki on Fluorescent lighting says:
CCFL cold cathode fluorescents are very thin tubes that backlight LCD monitor & TV displays. CCFLs are also used in scanners. "
Under -
Can I re-use my scanner/monitor CCFL?
CCFLs for these apps typically use a very high colour temperature tube, which gives a very cold looking light "
So LCD monitors tend to make things look much bluer, than they actually are.......
