Re: Nitecore "Tiny Monster" TM11 (4x18650, 3xXM-L) Review: RUNTIMES, BEAMSHOTS, VIDEO
Selfbuilt say in his original review that he would not recommend the light be left to tailstand on Hi for any extended period of time. I have taken my RRT-3 XML and set it on the 2nd to highest 1200 Lumens level and used it as an area light for 30-40 minutes at a time and it was never hot to the touch with no active cooling.
A couple of comments...
I'm pretty sure you have valid points in your analysis (and this in in no way an attempt to shoot down your overall critique). However, I feel a bit as though you might be over-analyzing the technical side while perhaps deemphasizing the actual functionality of the TM11. I'm betting the majority of actual users of the TM11 would agree that its useful output and unique beam pattern outweigh what might be perceived as a couple of technical design weaknesses.
On the tail standing issue, it's true that running the TM11 in turbo mode (2000 lumens) while it's in tail standing position will lead to a lot of heat buildup (an uncomfortable amount, to be sure). But, I don't think it's fair to compare the heat built-up to the RT-3 when the RT-3 is set to 1200 lumens without doing a side-by-side test of the TM11 at a similar setting. When run for extended time on high (TM11 at 1100 lumens) the TM11 body does gets warm...but not hot. Despite the cautions by Selfbuilt in his early review, running the TM11 on high (1100 lumens) for extended periods does not result in the body getting overly hot to the touch -- just warm, and not so warm that anyone should be hesitant to grab it up from the tail standing position after an extended period. As a TM11 user, I've tested this personally, for extended times, both in turbo mode and on high setting (up to an hour on high, tail standing), and I don't feel that the cautionary statement really applies to the TM11 high setting.
Not trying to argue with your rationalizations (I think you made some solid points)...just putting out a slightly different perspective.
