I have a new Nitecore D10 PD R2 and the ramping is now Hi, Med, Low, It does not change according to how long the switch is held. It just cycles through the Hi, Lo and medium. Is this normal? Also the color is almost green?
I have a recently purchased PD D10 R2 (not an SP) that I carry in my pocket and it doesn't seem to have a three stage thing but what it does have is a very fast jump from low to medium then much slower to progress from medium to high. Seems to be slower all the way back down from high to low in the other direction.
After a bit of "real world" use of my ramping D10 R2 I'm rapidly coming to the same conclusion as you. It sounds picky I know, but waiting for the light to ramp is inconvenient when you need it to change immediately so the SP UI would probably be quite good for me.I realized that as novel as the ramping is, I find the 3 level UI more convenient. You can "tap" the ramping UI to go from Low to High and vice-a-versa, but having the medium available much more quickly is more convenient than ramping.
