Linger
Help me out here, i'm trying to make sure I have this right.
This means that dis-assembled rv battery packs, full of 'new' li-ion cells in convenient and attractive formats, are a bad idea for modded flashlights. The discharge in 'high' can exceed the cells abilities, and it may ... (I don't know what it may do, but i suspect it is bad.)
If the cells are from dis-assembled rv packs they do not come with any indication of what their capabilities are. If the flash-light is regulated, can the cell still be pushed beyond its limits and lead to some discoloured tail-springs and funky smells on openning. Won't a regulated flash-light limit the current the battery can discharge? meaning that the cell cannot go into thermal run-away because the flash-light limits the charge it will accept?
Best,
Linger
there's evidence dentrites can form during discharge at higher currents than mfg spec's... dentrites form as sharp crystals which can pierce internals, leading to dead shorts. which will not show up until cell is fully charged.
Best,
Linger
