So if side switches are your thing, does this beat the T27?
Wow you got 650KCD from the W2 version!??? They rated the W1 at 650KCD. I guess I measure Kcd High. But its OK. still relatively correct with my other lights. By the way I report all Emmisar and other Narsil/AUdril light numbers at Turn on.
I would love to see the W2.1 in there but not sure if you can add some resistors to increase the current. We will see.
Not sure..I vaguely follow his work...Isn't 10-20% pretty typical? I'm going to guess 750kcd territory.
I have to decide if the performance increase is worth it.
20% and more lumens, I'd pop for it.. but it's hard to order something to be made, in order to find out how it performs...
I believe Vinh is saying that he measured the stock W2 at 1000L and 650ckd. I was guessing 10-20% more throw for the W1.1 (maybe 750kcd) but perhaps 300 fewer lumens than the W2.
That would be drastically different from manufacturer spec. The Noctigon site says it should be 1400L, 550kcd. But I don't see any details on Vinh's site that would explain the discrepancy...
I'm trying to figure this out, because I just ordered a K1vn with W2 and have no clue what type of beam to expect! I chose the W2 so it wouldn't be such a laser like the W1, but if Vinh's mods basically turn his W2 into a W1, what's the point?
Why on Earth would Noctigon make a single emitter light incapable of working with a protected 21700?
Because when the protection circuit trips, users blame the manufacturer and it happens often
