I'm lookikg to pop by noob cherry by converting a Niteflux VisionStick Halogen 10 to an LED emitter. Konalover posted this thread asking for guidance about building a light and BrianMc replied with several links, one of which was for the Cutter Electronics MCEQUICCpower light engine, which looks like it might well do the job for me.
Some background. I bought a Niteflux VisionStick Halogen 10 about 2 years ago, thinking it would light the way on my (mainly) rural commute to work. Sadly, I soon found out that either (a) my eyesight is worse than I thought or (b) claims from other buyers in their reviews that it 'lit the road ahead superbly' were a tad wide of the mark or (c) both! I resorted to using both the Halogen 10 and the Cateye EL610 I'd previously bought (thinking it was the dogs cahuna's a the time, only to be gravely disappointed) until I found that once could buy the headlights on their own from Niteflux. Since Niteflux dealers in the UK are rather scarce for some reason I bought the unit direct from the manufacturer, but since they are in Australia and I am in the UK, I got stung by Her Majesty's Robbers and Cutthroats to the tune of £20 on top of the purchase price, which added up to nearly £90! Since I am ny nature both a skinflint and a womble, I decided to see what there was in the way of DIY solutions.
Anyhoo, to business;
The halogen-driven guts of the light at present look like this:
On the left is the standard Halogen 10 insert, on the right is the innards of the Enduro 8 headlight unit. As far as I can tell, the small PCB in the halogen headlamp is just to give the on/off switch somewhere to go and for the various connections to be neatly done. My intention would be to replicate the aluminium housing you can see on the right hand module to give the Cutter engine somewhere to sit (I am lucky enough to have access to a centre lathe).
This in the lens from the Enduro 8.
From Googling this it looks like it might be a Ledil?
My questions are, do the far more experienced amongst you think this will work OK?
Is this engine a fit-and-forget i.e. do I need anything else (on/off switch, lens and battery excepted) to produce a working light?
Will the standard Niteflux battery be man enough (2200 mAh, 11.1v)?
Is this engine simply an on/off or does it have hi/lo power/flash modes?
I apologise now if I ask what seem like stupid questions, (a) I'm a noob, it's what we do and (b) the only stupid question is the one you don't ask :thinking:
Thanks in advance.
Thanks in advance.
