No longer selling these... Please read this:
http://www.laserpointerforums.com/forums/YaBB.pl?num=1231511226/0
Using the Kryton version 1 barrel, it was easy to build a green mod without any modifications to the barrel... (except one very small thing)
The green modules are here for the specs on them:
50mW: http://www.o-like.com/b2b_cpinfo.asp?id=882
100mW: http://www.o-like.com/b2b_cpinfo.asp?id=909
No, they are not IR filtered, but for the price of these modules, I'm not complaining!
This is the only modification that I did to the barrel... I just drilled it out 'a tad' here, in order for the module to be able to slide through...
The key to this build, making it a simple and well built mod, is this custom little heatsink which also allows you to adjust the position of the module length in the tube...
I have this set up for using a single 3.6 volt RCR123 battery (or 3.0 volt). But if I wanted to, it would be easy to slightly bore out the barrel to fit a 17670, or an 18650. And then mount the module from the front. (Kryton Groove is already fit for an 18650)
(50 mW Beam shots - with some smoke)
What a great design these barrels are from Kenom!
Improtant: You must 'handle with care' at this power. It can damage the eye instantly with a direct shot. Proper eye protection is recommended.
These 50mW and 100mW Standstone11 green modules are not IR filtered. But I have some IR filters, and the difference in the measurement is only about 10mW's or less with the IR filter (50mW module). And about 20mW's or less with the 100mW module.
These modules don't seem to have that 'slow climb' in power like the cheap DX greenies, the 50mW ones start out, at or above 40mW's and climb to over 50mW's with in 10 seconds in normal room temperature! The 100mW modules are overpowered as well!
Jay
Jay
