SenKat
This is part two of the review of Nova Lasers excellent selection of optical accessories !
This review will focus on many items - first and foremost - the beam visualizer spray that they offer. The Beam Visualizer Spray I am CERTAIN some of you have seen on CSI episodes, or spy movies - it is an alternative to lugging around a fog machine everywhere you go, and most definitely MUCH MORE healthy than puffing away on ciggarettes to make the beams stand out for our photos better (cough ! cough !) So - without further ado - the Beam Visualizer Spray !
Here is the Beam Visualizer spray in action - catching the beam as it reflects off of Nova's Mirror stands - holding a FS (Front Surface) Mirror !
Here is the "setup" :
Nova Lasers X-85
Nova Lasers FS Mirrors (one leaning on the stands - showing the protective blue tape that covers the mirrors)
Nova Lasers Beam Visualizer Spray Can
Now THIS setup right here is INCREDIBLE !
The triagular shaped plexi-glass stands are multi function - they are called :
Deluxe Accessory and Optics Holders !
They assemble so : you screw the small screws into the bottom (3 of them) to make it stand up easily. It has a slot in it for a FS mirror, three holes in front of the mirror slot, designed to hold the aligator clips in place to hold matches, or any other material. There is a hole centered behind the mirror slot where you can insert the other holding accessory - by depressing on a part of it - it adjusts in size to gently clamp down on almost anything at hand !
This shot shows two mirror holders in action, reflecting the beam from the X-85 nicely !
Sam shot as above, with less light to pollute the pic :
Here is a shot with the upper clamp assembly in action - holding my favorite book of pre-sharpied matches !
Here is a closeup view of the optics stands, with the aligator clips installed, and holding matches :naughty:
Here is a side shot of the FS mirror in an optics accessory stand :
I have to thank Nova Lasers for sending me all these wonderful items to test - to sum it all up - simply incredible ! These little optics stands are the PERFECT accessory to your experimentor's table ! Check them out here : NOVA
Nova Lasers X-85
