MikeLip
OK, yeah. I am an electronic engineer and I spent 5 years as a computer programmer. I am trying to sort out the 85P. What I want to do is make it go from low to max in four steps, then off.
Funny thing is that programming the NovaTac flashlight is like learning something new on the computer - Hell followed by Nirvana once you get the hang of it.
Get into the presets as follows:
Now once you get into each mode just click-click-press/hold and you will cycle through the brightness levels and various strobes such as disorienting strobe, SOS, etc. After you get to the brightness level you like shutting the light off with a click will save the setting for that preset or mode.
- Primary mode it's one click
- Secondary mode is 2 clicks with the light turned on
- "Minimum mode" is 3 clicks with the light turned on
- "Maximum mode" is Click/Press with the light turned on.
THAT I can handle - thanks! Why doesn't it say it that clearly in the manual?![]()
Yep, I do! Thanks everyone! I feel kinda dumb, but I should be used to that!![]()
