After using the search feature it sounds like this has happened quite a bit...
My new black 85T from Lighthound has a brief flicker when going from high mode (85 lumen) to lowest mode (0.3 lumen). Also there seems to be an occasional random flickering once or twice when kept on the lowest mode (0.3 lumen). The serial # is in the 3xxxx series if that makes any difference.
Doesn't seem to be causing any major problems, but is this an indicator of a bigger underlying problem or a bad unit?
The LED tint (slightly warm, definitely warmer than my SF P60L) and centering on my unit is about as close to perfect as far as I can tell. There are a few flecks of dust on the reflector and LED bubble, but so be it. I'm not in a big rush to return it unless really necessary. My only real complaint... wish I had tried out the Novatacs earlier!
Any advice from the experts here on CPF? Thanks :thinking:
