Sold/Expired NOW ACCEPTING DEPOSIT +++ The Mammoth (4 x 18650 Body Size) +++
H22A
Thailand
*Battery holders not included
Remove 2nd body section to make it a "Shorty"
Hello Everyone,
This is my second attempt at Mammoth project. The first attempt fails because I couldn't muster battery holders design as I would like. So, this run I will not be offering battery holders. If you are interested in custom battery pack please contact LuxLuthor or fivemega.
Price is slightly higher than previously quoted due to higher material cost and weakening US Dollars. Here is what I have to offer.
Head consist of head and lens and nothing else.
Material: 6061 Aluminum
Diameter: 113mm
Length: 116mm
Reflectors (not included): Will fit 7 x McR-27S, 12 x McR-19XR (estimated) and 4 x Fraen Ostars reflectors
Lens: 89.5mm x 2mm Schott Superwite
Heatsink: Adjustable threaded body for various reflector sizes
Finish: HAIII Natural and HAII Black
[highlight]Price: $250.00[/highlight]
Head fits M@g "D" as it has the same thread. If you already have Tri-bored Mag D and 3x17670 battery holders by Fivemega, you are ready for Mammoth.
Body (2 piece construction)
Material: 6061 Aluminum (made from solid aluminum bar not tube)
Diameter: Outside 50mm, Bore 45mm
Length: ~270mm
Body: Two-piece construction (see picture) with adjustable spring height tail cap
Battery (Not included): Design to work with 4 x 18650 and 8 x 18650
[highlight]Price: $155.00
[size=+1]Optional[/size]
- Body extension for 12 x 18650 : $50.00
- Shorty body(as in 4th pic) + adjustable tailcap : $105.00[/highlight]
Body is two-piece design which allows for you to stack up batteries in combination with number of LEDs used, whether 4 x 18650, 8 x 18650, 12 x 18650 up to your imaginations.
Design calls for body that is capable of handling custom battery packs and battery holders(should someone decided to make one), which by the way not the same height. I was able to come up with adjustable tail cap spring height, with up to 25mm travel length. Spring sits in threded body housing which threded into the tail cap. Therefore, eliminates the hassle of cutting spring. I'll post pictures as soon as I receive the drawings.
Body does not come with M@g switch or spring. I believe that it is much easier for you to acquire in your country or remove from any M@g D that you have lying around the house. Installing switch and spring are as simple as you would on M@g D. Simply transferred M@g D switch and spring over to Mammoth and you are done. No modification needed.
CNC shop require MOQ of 25pcs each. To make this a reality, I would like to find out how many people are interested. "Serious inquiry please". Once the minimum order quantity is reached, I'll ask those stated interest for 50% deposit. Sorry I don't have cash outlay to get it started without your help Estimated lead time is 2 months.
Payment by PayPal cash or credit to nongvol1@asianet (dot) co (dot) th Credit card please add 4% Do not pay at this time
Shipping is by regular mail. Registered mail please adds $5.00 and I'll be responsible for lost mail should you decided to choose this option. Otherwise, I'm not responsible for lost or undelivered items.
I'll let this run for a while. If 25pcs MOQ is not met, I'll have to scrap the project.
Cheers,
H22A
Re: +++++ The Mammoth +++++
[highlight]Interest List[/highlight] Last Update: June 27, 2008
[highlight]Complete Set (Head+Body)[/highlight]
1. tanasit = 1 head, 1 body (HAIII NA), 1 head, 1 body (Bare Aluminum)Deposit Received
2. Icarus = 2 heads, 1 body, HAIII NA Deposit Received
3. kenster = 1 head, 1 body (HAIII NA) Deposit Received
4. donn = 2 heads (HAII black and HAIII NA) Deposit Received
5. DFiorentino = 1 head (HAIII NA) Deposit Received
6. karlthev = 1 head (HAIII), registered mail Deposit Received
7. white light = 2 heads, 2 bodies (HAIII NA) Deposit Received
8. starfiretoo = 1 head (HAII black), registered mail Deposit Received
9. Rommul = 1 body (HAII black) Deposit Received
10. X_Marine = 1 head (Bare Aluminum), registered mail Paid in Full
Total = 14 Heads, 9 bodies
[highlight]Body Only[/highlight]
1. cnjl3 = 1 body, 1 extension (HAIII NA), registered mail Deposit Received
2. elnino = 1 body (HAII black), registered mail Deposit Received
3. donn = 2 bodies, 2 extension (HAII black and HAIII NA) Deposit Received
4. william lafferty = 1 body, 1 shorty (HAIII NA) Deposit Received
5. LuxLuthor = 1 body, 1 extension (HAIII) Deposit Received
6. Rommul = 1 shorty (HAII black) Deposit Received
7. JosephK = 2 bodies, 2 extensions (HAII black, 1 body HAII black)
8. karlthev = 1 body, 1 extension (HAIII NA) Deposit Received
9. Action = 2 bodies (HAIII NA) Deposit Received
10. nanomiser = 1 body, 1 shorty, 1 extension (HAIII NA) Paid in full
11. dan = 1 shorty (HAIII NA) Deposit Received
12. Rookwood = 1 shorty (HAIII NA) Deposit Received
13. 9x23 = 1 body, 1 extension (HAIII NA) Deposit Received
14. DFiorentino = 3 shorty (Bare, HAII black, HAIII NA) Deposit Received
15. X_Marine = 2 bodies (Bare Aluminum), registered mail Paid in Full
16. Raoul-Duke = 2 bodies (HAII black) Deposit Received
17. kenster = 1 extension (HAIII NA), registered mail Deposit Received
18. gswitter = 1 body, 1 extension (HAII Black), registered mail Deposit Received
19. Icarus = 1 Shorty, HAIII NA Deposit Received
20. Starlight = 1 body (HAIII NA), registered mail Deposit Received
21. Scarbear = 1 shorty (HAII black) Deposit Received
22. thomashct = 1 HAII black, registered mail Deposit Received
Total = 19 bodies, 10 Shorty, 12 extensions,
Sawasdee krup,
I am in for at least 1 set. :thumbsup::thumbsup:
Come on folks, let's make this happen.
Thanks,
Tanasit
interested in the body :twothumbs
I would suggest selling the 4x18650 body only and the extension seperatly.
Is it possible to have a version with a tailcap switch instead of the side switch (to make it shorter) if there is a demand of them ??
Body extensions are sold seperately. I agree with you that tailcap switch would make body considerably shorter, but on operational side that would be difficult to operate the switch. This is big and heavy light.
A tailcap switch will make it shorter but nearly impossible to implement drivers such as the B-Flex.
Keep the magswitch :)
Sorry to let you know but I changed my mind... :aaa:
I'll take two complete lights now... :D
(head + body, no 12 cell extention)
Both in HAIII Natural. :)
BTW Great drawings! :twothumbs
Better start a Mammoth interest list right now. :whistle:
+1 the light would be useless without the Magswitch!
Hi Benny, :poke:you forgot to post how many lights you need... :thinking: ... at least one for every hand I guess! :grin2:
I'm not home and have to think this one out but will by this weekend at latest!!!:twothumbs
karl
Im still debating with myself :D
:grin2:
But im leaning towards 2 complete packages.
Setapong - I am still in for the full kit. HAIII Black please.
BTW - will you also offer the smaller head discussed in the other thread? If so, I am interested in one.
Thanks,
Kirk
Benny, you know you can NOT live without at least one. :nana: HEHE!
Oh yes, I am posting my serious interest for one complete light. (1 head & 1 body) :thumbsup: Just found the thread so I may up my interest after I get over the initial shock of this........ :huh:
:eek: Mammoth! :faint:
Thanks,
Ken :grin2:
I would be in for at least one body and maybe one extension.
I'll be in for at least one head and a few body segments in black.
Any chance of doing some of the tubes with a ~27mm bore, to handle Emoli, A123 and AW C cells?
Thanks,
Ken :grin2:
+1 Who can say it better than the Kenster
Have explored quad boring the body to reduce the diameter? At 50mm it is huge. A quad bored body allows the use of 4x18650 packs as well as 3x18650 packs without rattling.
At any rate I am in for a complete body. To clarify: for $180 we get everything in this picture except the head right?
Thats what i am looking for.
That's correct. You get two-piece body and tailcap without the head.
