houtex
Is there a light that has the same UI and/or switch like the M30? I really like this light but want it or need it to be a bit smaller. I like strobe and being able to access it on the tailcap is neat.
Can you use protected 18500 cells or do they need to be unprotected to fit in the M30?I don't think so.
AFAIK the UI for the M30 is unique with regard to the sideswitch being used to change levels and the tailswitch being
a clicky with forward momentary-on for each level.
I use the light without the extender with 2 18500 cells. (2 18500s are equivalent in length to 3 CR123s.)
In this configuration the light is about as compact as you can reasonably expect for the power it outputs.
Thanks. Just ordered some. :DI use 2 protected 18500's and they work fine.
