I went to post this in the Flashlight review section but was denied and couldn't so here it is here.
They say that first impressions are lasting ones and with the Olight T20-T Q5 its all good. From the moment you first hold the light you can tell the build quality is excellent. When taking the tail cap off to put your batteries in you can feel how smooth the threads are and believe me its as smooth as! The machined knurling in the middle of the light is aggressive but not sharp and allows for a solid hold on the light in numerous conditions. The reflector has an orange peel effect close to the led and turns smooth about half way up the reflector. The body has flat sections milled into it allowing the torch to sit flat and not roll if placed on a flat surface.
The T20-T Q5 is the tactical version and has 5 different lighting levels that are accessible by turning the light on and turning the front bezel 1/8th of a turn and back again. Very simple and even I got it right the first time I used it. The switch also allows for momentary on/off if required. The last brightness setting is also memorised for the next time you turn the light on. If you require the Strobe or SOS feature it is available on the "M" version but you will lose 2 brightness settings. No biggy.
How bright is it? Very bright in a nut shell! I compared it to my Streamlight Scorpion with a Xenon globe, which is rated at 70 Lumens, and it appeared to me to be at LEAST twice as bright and a whole lot whiter in colour (I was using Panasonic Lithium CR123A batteries). The specs state that the maximum lumens is 220 but I have no way of testing that but I took the light for a test run out side and its throw has to been seen to be believed! I could easily see objects almost 60 metres away with no problems at all. At the lowest setting its still way bright enough to light your pathway when walking or doing work in the dark. The beam is very circular, crisp and very clean. Also the olight is water resistant, anti shattering and anti scratching. It is built to MIL-STD 810F standards and is Hard Finished with Type 3 anodization.
Below are the specifications :-
[FONT=arial,helvetica,sans-serif]Utilises the very latest Cree XR-E Q5 LED with a lifespan of 50,000 hours[/FONT]
[FONT=arial,helvetica,sans-serif]Uses 2 x CR 123 A Batteries[/FONT]
[FONT=arial,helvetica,sans-serif]Five levels of constant Brightness: 220 lumens (1.5 hrs) - 100lumens (3.8 hrs) - 44lumens (10hrs) - 18lumens (30hrs) - 7 lumens (70 hrs) Max 220 Lumens [/FONT]
[FONT=arial,helvetica,sans-serif]70 Hours of runtime on the 7 lumen brightness level![/FONT]
[FONT=arial,helvetica,sans-serif]No SOS or Strobe modes[/FONT]
[FONT=arial,helvetica,sans-serif]Digitally regulated brightness ensures consistent brightness throughout the life of your batteries[/FONT]
[FONT=arial,helvetica,sans-serif]Tactical Momentary-on forward Switch[/FONT]
[FONT=arial,helvetica,sans-serif]Cigar Hold for tactical application[/FONT]
[FONT=arial,helvetica,sans-serif]Auto-memorisation of the current level when powering off[/FONT]
[FONT=arial,helvetica,sans-serif]Accessories: One lanyard, two spare O-rings, one tail cap and one holster.[/FONT]
[FONT=arial,helvetica,sans-serif]Length 128.5mm [/FONT]
[FONT=arial,helvetica,sans-serif]Weight 68.5g (with no batteries)[/FONT]
Batteries Not included.
The kit comes with, of course, the olight, holster, 2 spare "O" rings, lanyard and tail cap. An optional pocket clip is also available.
Is the light worth the money? You bet it is! I'm very happy with it and I think you will be too.
mulder89
On a closing note I purchased this light from Extreme Torches here in Australia and the service was nothing short of superb!
I sent several emails asking questions and received prompt responses and a recommendation for a light which turned out to be spot on. To add icing to the cake I ordered the light Monday afternoon and I had it Tuesday morning. You cant do better than that!
So to Luke and Extreme Torches I salute you and your fantastic service.
Added Beam shots
Brightest setting
Second Brightest Setting
Third Brightest Setting
Fourth Brightest Setting
Lowest Setting
All on a wall about 10 feet away. I dont know the camera setting as it was on auto, no flash.
Reflector
Middle of Light with Knurling
Head Circuit Board
And of course the torch its self
I hope you like the photos. Sorry they are not the best as I took them inside in low light.
mulder89
mulder89
Added Beam shots
Brightest setting
Lowest Setting
Reflector
Head Circuit Board
mulder89
