Olight WMvn 2 - Best 18650 Carry? R
Skylumen
  • Factory Link Here
  • Stock SST40 6500K @2s:
  • NWvn SST40 5000K @2s:
  • NWvn XHP50.2 6500K @2s:
  • NWvn XHP50.2 SDCE @2s:
  • Large defined filled hot spot with wide faint spill
  • Genius momentary tactical rear switch UI: Quick 1/2 press for constant Low and full press for constant Turbo. Press and hold for momentary.
  • Perfected side switch UI: From OFF press N Hold = Moonlight. From ON press N Hold cycle Low-Medium-High. Double click = Turbo. Triple Click = Strobe.
  • Convenient magnetic charging with button status LED indicator.
  • Stainless strike front and rear bezel
  • Deep carry tip up & down pocket clip
  • Additional removable lanyard ring
  • Proprietary 3500mAh 18650 included
  • Excellent quality silicone lanyard and carabiner ring included
  • Performance aside what more can we innovate from here?!
  • What an EXCELLENT light!
Purchase Here: https://skylumen.com/collections/v54-lights/products/olight-nwvn-2-best-18650-carry-r
Played with this light some more...Really made me slow down and think...What's next? This is perfection already...
Wnderful. Interested in seeing the numbers to your sst40 6500k and your xhp50 sdce versions
Is a sbt90 possible for this light? This might be the ideal tactical edc for me and a buddy of mine. So we want the best max performance.
edit: I also would like to know if xhp70.2 would be possible.
Is a sbt90 possible for this light? No This might be the ideal tactical edc for me and a buddy of mine. So we want the best max performance.
edit: I also would like to know if xhp70.2 would be possible. XHP70.2 SDCE may be.
Wait so the stock light with sst40 1750 lumens is brighter and throws further than the nwvn xhp50 sdce version at only 1500 Lumens?
I have not measured the stock light but my numbers are never to be compared with stock numbers.
Yes I know that. Your numbers are always conservative. But I guess I was just shocked to see only 1500 lumens for a xhp50. You have modded many lights with a xhp50, and I'm not sure I have ever seen one this low. Maybe once, but I think it was a light that used a much smaller battery. Curious to see the numbers for the sst40 version.
  • Stock SST40 6500K @2s: 1400L, 17Kcd, 261m
  • WMvn SFT40 6500K @2s: 1300L, 23Kcd, 303m
  • WMvn XHP50.2 6500K SDCE @2s: 1500L, 12Kcd, 220m
