bestyman
- Joined
- Mar 5, 2008
- Messages
- 6
Pleaae can someone explain this.
I recently bought a romisen RC-T5 and some ultra fire16340 protected cells.
I am only my second charger having thrown the first one away thinking it was faulty. I am now using a ultra fire charger.
The flashlight works fine on duracell disposable c123 batteries( 3.0 volt) but something very strange happens when using the rechargeables.
I have 7 batteries to use all charged to 4.16 volts. The light takes 3 or 4 batteries. If I put 4 batteries in the light lights up very dim so after a few seconds I check the voltagesand 3 batteries are almost the same but one battery is ZERO volts.
I then try again but shortern the light and put in 3 good batteries, the light usually lights up with a slight flicker then goes out or very dim after a few seconds. Again one of the batteries reads zero volts.
The batteries work ok ( 2 at a time) in my ultarfire c2 so I dont think batteries are the fault.
Like I say , the Romisen works fine on duracell disposables so Im not sure the light is faulty .
Suggestions please, anything I can check ?
Thanks
Mark
ps I put the 2 batteries at zero volts on charge and within a minute or so they were back up to 4.2 and working fine in my c2........perhaps they had not gone flat? could the protected bit on the battery have kicked in and shut off??
Should i try unprotected cells?
Can I convert a protected to an unprotected?
EDIT the flashlight now works on 3 cells but when I put 4 in it goes very dim / off and the last cell goes to zero volts.
Thanks
Mark
