warlord
So I was polishing up some E0 reflectors and I decided to see if my new torch could be improved with a little polish. So I proceded to disassemble it an began polishing with some aluminum/mag polish. Boy what a mistake! It was nice enough looking before but I couldn't leave well enough alone.
BEFORE:
And this is what it looks like when you polish away the shiny reflector coating, which doesn't take very long.
I thought to mysef what have I done? This is supposed to be a solid aluminum reflector, not some cheezy plastic POS. Then I realized that the easiest way to make an OP reflector out of aluminum wouldn't be to machine it. It would be some sort of textured coating.
Keeping that in mind I looked at it again. Now, it looked like some sort of rough textured anodization. Ironically, it's orange:thinking:. I figured if I could remove this layer I could get down to the aluminum again, polish it and have a nice smooth reflector. Not to mention pretend that I did it on purpose, LOL.
So try as I might I couldn't get it off with polish, acetone, or aircraft paint stripper. I don't have any lye around the house so I had to fabricate some mini wet sanding paper and remove the coating manually.
Mini wet sanding paper:
And what 30 minutes of my life looks like:
Looks pretty good,eh?:twothumbs
A little polish:
And the after picture:
So, long story short, If you have better things to do with about 30 or so minutes of your life ~DO NOT POLISH YOUR REFLECTOR!!
But I'm still pretty new here and you guys probably aready knew this.
Thanks for reading.
BEFORE:
A little polish:
Thanks for reading.
