Hack On Wheels
Hi all,
I'm trying to troubleshoot a problem in a light I just put together. From the (admittedly limited) testing I've done so far, the batteries seem like a likely cause of the light working intermittently.
The symptoms are not entirely consistent, but it seems to follow the trend of being less likely to work the more pressure that is put on the batteries. I can get the light to work indefinitely by making a connection with the tailcap before I screw it in (conducts through the threads). As soon as I screw in the tailcap I can't guarantee it will work, sometimes it turns of right away, sometime I get the tailcap almost fully threaded, occasionally it will still work for a bit with the tailcap fully threaded in. Once it stops working the only way to get it to work again is to remove the tailcap and start over.
For reference, the light is a Minimag with a copper heatsink that has an SOB1000 converter mounted. The batteries are 2 Trustfire 14500 Li-Ions (unprotected), so I know the quality isn't the highest. There isn't much extra room in the battery tube once the tailcap is installed, maybe 2-3mm. I don't notice any heat (not any more than what is probably residual heat) when the tailcap is installed but the light isn't working, so I don't believe the batteries are being shorted either.
Really what I'm wondering is: are the batteries constructed in such a way that they could have an open circuit under enough pressure? Any input on this would be great. :candle:
Thanks!
Thanks!
