DEar AACycler refer to your investigation:
http://aacycler.com/post/opus-bt-c2000-vs-opus-bt-c700/
This is a nice job that I appreciated, thank you!
Regarding the BT-C700 there are 2 versions, I have 3pcs of the first version and only one piece of the second version.
What I didn't understand is which version of the BT-C700 was used in its test.
There is a difference in charging poor or cheap batteries, where the second version delivers the maximum current for a longer time (the value of 1000mA) than the first version.
Some time ago I had checked the value of the Minus Delta V, which turned out to be 2mV, as in the image below, but things don't always go so well with cheap batteries:
In any case, the BT-C700 delivers a pulse current of about 1000mA (As confirmed by the HKJ test) even when charging at only 200mA effective the current is formed by short pulses of 1000mA.
The thermal effect on the internal resistance of the batteries (mainly heat) is definitely higher than 200mA of true constant current.
