Re: Ordered a Mill, now question on a good, non top-of-the-line vise
Here's an interesting bit of somewhat hard to find info ... some companies like ETM make only metric sized collets but the catalog companies like Enco list them in English units
Other companies like Lyndex (sold by McMaster) make both metric & English. Does it really matter as the ER collets all have a range of collapse of 1mm ... YES it does.
A collet sized 3/8" has a range from .344" - .375". Slide any 3/8" tool into that collet & it fits like a glove.
A collet sized 10mm has a range from .354" - .393". A 3/8" shank rattles around like a bucket of bolts, although you can tighten the collet up enough to close down on the shank.
The collet that has a sliding fit is the best choice. TIR is lower & breakaway torque is higher. No matter which collet set you purchase be sure to remember that most sets are metric, even if marked in fractional inches. If a shank drops through a collet be careful - for light cuts that aren't critical you may do fine. Push a 3/8" twist drill hard into 4140HT, using a 10mm collet, and you may see what I witnessed - drill stops & spindle keeps spinning. Scored the crap out of the drill shank & into the trash it went. Left the same score marks inside the collet so that one went to the trash as well. Had I been smart a 3/8" collet would have been purchased sooner than later.
Is there a brand of R8 collet chuck that is along the quality lines of the Albrecht drill chuck? And what is a "good" brand?
The Bison collet chuck is well made. I've not seen an ETM collet chuck but their collets compare well with Bison, perhaps a little nicer. For "Albrecht quality" the most beautifully machined collets are Lyndex from Japan. Mirror finished inside & out, super low TIR, so nice to look at that you almost hate to use them.
I've never seen the Royal Ultra Precision ER collets but expect them to be similar to Royal live centers - world class. Techniks collets get good reviews on most machining forums & would be worth a look.
