Alan B
This is the ordering and sales thread...
Above is the first article Regulator SN001 that LuxLuthor Reviewed (see link below)
The regulator that we are shipping has mostly surface mount parts so is not quite as crowded as the above unit
Dropin PHD-MD (Programmable Hotwire Driver for the Maglite D)
Thread Table of Contents
1. Introduction (This Posting)
2. Order Status List
3. Model Order
4. Configuration Program Instructions
5. Reserved
6. Ordering/Sales thread begins
Programmable Hotwire Regulator Ordering Information
This Order/Sales thread is for the Programmable Hotwire Regulator shown above. Features and Specifications are in related threads, see links below.
In this thread we convert the Feeler list into an order list. Choose your parameters and features and commit to ordering quantities. The order of production will follow the Feeler list. New parties may also order, they will go at the end. Do not pay until directed to do so. Realistically significant quantity production deliveries will probably start in early July as June is already very busy on other work. If you wish to cancel and be dropped from the list please post here or send a PM or email.
Programming the Regulator requires both the Programming Adapter and the USB Programmer. The Adapter brings out the programming socket and provides a pushbutton for testing the flashlight program. The USB Programmer interfaces to the computer. The Programmer is available from multiple sources for about $35 plus shipping, I include it here for those customers who want the convenience of one order. Buying the programmer from me costs a bit more since I have to re-ship and repackage it, and I need to pay my kids something for the effort plus the PayPal fees. Only one Programming Adapter and USB Programmer are required for many regulators, it is removed once programming is completed. For more information on available programmers and purchasing them see the Programming thread linked below.
New Semi-Kit - In this configuration the regulator PC board is built (but not tested), and provided with the aluminum sled, switch pcb and parts, and regulator board mounting hardware. You add your socket and socket spacers and assemble the switch pcb and do the final assembly and programming on the unit. A USB programmer and programming adapter will be required, as well as a dc meter for calibration. Refer to article 4 in the discussion thread for Semi-kit assembly notes before ordering. This kit is for advanced builders who can deal with the tight spaces and small through-hole soldering required.
The New Semi-Kit-Plus is the above Semi-Kit with the addition that we test and program the regulator board. You still need to solder the switch pc board and assemble the regulator board with your socket into the sled. Assembly is the same as the Semi-Kit however Testing and Calibration is not required. This kit is for advanced builders.
If you have questions, visit the Discussion thread and check the FAQ and documentation there, as well questions asked by others. This thread is for orders.
Discussion goes here:
http://www.candlepowerforums.com/vb/showthread.php?t=231656
Price List
Payment will be via PayPal to sales at akbeng dot com unless otherwise arranged. Prices subject to change.
Drop-in Regulator (Assembled, Tested, Programmed and Calibrated) (includes basic socket and switch assembly): 97$
- Install User Supplied Socket: no charge, must be provided prior to final assembly
Standard Socket: (included in base price)
Kiu Socket upgrade (subject to availability, may cause delays): 10$
- if you provide us the Kiu socket there is no charge for installing it
Spare Pushbutton switch assembly: 9$
Programming Service: 9$ (return the regulator for reprogramming and recalibration, plus shipping)
Drop-in Regulator Semi-Kit (Assembled Regulator board (untested), switch board kit, aluminum sled and pcb mounting screws): 80$
Programming Adapter Assembled: 12$
- (only required if reprogramming the regulator, one adapter handles any number of regulators, USB programmer also required)
Programming Adapter Kit (pcb and parts): 8$
Two programmers are now available. They are both USB. The Mini USB programmer is very small, and has no housing. The Atmel programmer is much larger and has a plastic housing. They both do the job well. I expect to stock a few of the mini programmers but the Atmel unit will be ordered as needed. Both units include USB and ISP cables. To program any number of Regulators one programmer and one programming adapter are required.
Mini USB Programmer: 25$
- 13x15x35mm
- compatible with AVR Studio and AVRDude programming software
- compatible with phdConfig.py, the new Regulator configuration software
- ships free with regulator order
Atmel USB Programmer: 45$
- 28x57x74mm
- (available directly from various suppliers, nonstock item, may delay order)
- (one can program any number of regulators and other AVR projects)
- additional shipping required for this programmer
Shipping without Atmel USB programmer
- USA Shipping: 7$ per 1-2 regulators, $9 per 3-5 regulators
- Foreign Shipping: 19$ per 1-3 regulators
Shipping with Atmel USB programmer
- USA Shipping w/ Programmer: 19$ (up to 3 regulators can ship with it)
- Foreign Shipping w/ Programmer: 29$ (up to 2 regulators can ship with it)
Repair Service: <tbd>$
- On orders delivered to California addresses we must collect 8.25% sales tax - add this to your payment
- Note that $1 from each Regulator purchase will go to CPF, and Nanomiser will get 2 Regulators for his excellent Solid Modelling effort.
Related Threads
Review by LuxLuthor:
http://www.candlepowerforums.com/vb/...d.php?t=230519
Discussion, Documentation and FAQ:
Feeler:
http://www.candlepowerforums.com/vb/...d.php?t=218506
Advanced - Programming the Regulator:
http://www.candlepowerforums.com/vb/...d.php?t=231685
Design Collaboration Part I:
http://www.candlepowerforums.com/vb/...d.php?t=186291
Design Collaboration Part II:
http://www.candlepowerforums.com/vb/...d.php?t=209098
Design Collaboration Part III:
http://www.candlepowerforums.com/vb/...d.php?t=220475
3. Model Order
5. Reserved
Price List
- 13x15x35mm
- 28x57x74mm
Related Threads
Feeler:
