i am planning some overhead offroad lights for work lights. the light setup would be 9 halogen 55w farmer lights forward facing (with the plan to add a second row of 9 led forward facing when i can afford the 125 apiece from larsen) plus 10 (4L 4R 2 rear facing) led on a halo (they are 2 rows of 3 so 6 diodes total? in a flood pattern).
now i have the 9 halogens and the 10 leds. the max amps i would be putting out if i had them all on at one time would be 62 amps (36 amps for the halogens and 27 for the leds. this formula was figured using a watt to amp calculator at 495 watts on a 12v system plus the instructions on the leds say 2.7 per pod).
the distance from the battery to the lights is about 8 foot give or take a few inches and i want the lights to think the battery is on the roof right next to the lights.
i have all the necessary accessory equipment for either set of wires, lugs, terminals, circuit breakers, relays, 10 slot fuse boxes, 4 slot fuse boxes, anti ox compound, weather proofing boxes, smaller wiring. when i say everything, i mean the only thing i dont have are capacitors to directly connect to the bulb for balancing continuous voltage with no flickering.
the question: i have about 20 foot of 4/0 aluminum service wire (the bundle with grey wrap where its 3 wires of insulated 4/0 and 1 wire of bare 2/0, so 60 foot total of useable wire) and i have 80 feet of 4 gauge copper thhn wire. so i have plenty of each type. i feel the 4/0 (single wire not bundled) would be ideal because it would have a .64% volt drop where the 4 gauge would drop about 2.05% according to an online volt drop calculator.
i know its overkill but what would be better realistically.
