ElectronGuru
Had a bit of trouble getting my Malkoff dropin installed in a new FM body, here are the details. Please note, I make no claim about the design or construction of either piece, my comments are limited to my own experience:
Combine FMs new SureFire 2C body with Malkoff dropin and appropriate bezel and batteries
But something is blocking the brass module from seating all the way in
This in turn, is keeping the head/bezel and body apart
Looking inside, the collar at the throat, separating the battery from bulb compartments inside the body is smaller than the Malkoff would like. Comparing the Malkoff, its bottom end is larger than FM's or SFs modules.
So breaking out my "high-tech" lathe
And applying a few hundred careful rotations
I have reduced the collar's diameter
Lowering the module down all the way
and allowing the head to do the same.
Also adding a bit of tape to the cells prevents any rattle or movement...
...leaving what I call my OxLite. Its not the smallest/fastest/lightest/prettyiest light in the drawer, but the 3300 mAh cells wrapped in HAIII (Z44 bezel) aren't going to stop without good reason
Here are some comparisons
and where she lives
Extra Info:
This step drill bit (originally purchased to enlarge aluminum reflectors)
is 7/8's at its largest, and barely fits inside the larger opening
-EG
and where she lives
Extra Info:
-EG
