P60 dropin for Streamlight propolymer 4AA 7 led
wechnivag
I was just wondering if a P60 Cree dropin can be made to work in a Propoly 4AA 7 led host? Is the diameter and length physically possible to fit in?
Another problem would be the battery orientation, and the 4.8V from 4 cells. But there are P60 dropins that can handle up to 6 volts right?
:thinking:
There are P60 drop-ins that can handle up to 18v.
As for fitting into a Propoly 4AA, I don't think it will work.
You won't be able to just drop it in, but if you worked out a way to replace the spring with a positive and negative contact that the SL PP 4AA 7LED needs becasue of it's battery configuration and get some sort of makeshift holder to keep the smaller P60 drop-in in place within the bezel, ... it should work find. :p
