Fizz753
While reading the thread titled "Dealextreme drop in for G2, 6P, etc???" I started making a list of the drop-in's I saw. It got a little out of hand.
I thought I would put the list out here instead of buried 10 pages in to the above thread (no offense to the guys and gals in said thread :wave
If someone wants to shamelessly steal the list and add to / keep it updated feel free. Since I unfortunately wont have much time to do so.
** Don't forget to check out the P60 Flashlight List {host} post as well. (and add to it if you can ) **
** Lumens Factory **
http://www.lumensfactory.com/cart.php?cat_id=2&sub_cat_id=0
D26-LED High Output Single Mode LED Reflector Module (3.6V-13V)
$24.00 - 3.6V to 13V Regulated Input for Maximum Flexibility - High Output Cree XR-E, R2 LED
Maximum Current Output at 1000mA - High Colour Temperature (Cool White, 5000K-10000K according to Cree)
High Temperature Resistant Orange Peel Coating - Every Reflector Module is Pre-Focused for the Ultimate Spot
D26-LED Selected Warmer Tint Version (Limited Quantity) (3.6V-13V)
$28.00 - 3.6V-13V Regulated Input - Maximum Current Output at 1000mA - High Output Cree XR-E, R2 LED
Selected using Integrated Photometric Sphere to have Warmer Colour Temperature (5000K-5500K)
** Dealextreme **
Ultrafire Cree, Regulator, Reflector 1x18650 2xCR123A Lamp Assembly
http://www.dealextreme.com/details.dx/sku.1343
$10.92 accepted voltage: 3.6V ~ 9.0V 900mAh regulator board Orange-peel aluminum reflector
3W Cree, Regulator, Reflector 1x18650 2xCR123A Module Set
http://www.dealextreme.com/details.dx/sku.1447
$12.80 accepted voltage: 3.6V ~ 9.0V 900mAh regulator board Orange-peel aluminum reflector
DX 3W Cree Module CM1
http://www.dealextreme.com/details.dx/sku.3214
$10.82 3.2V~9.0V Input
Beamshots + review at: http://www.light-reviews.com/cm1/
SSC 42180-T 3W Emitter Reflector Driver Module
http://www.dealextreme.com/details.dx/sku.4068
$13.79 Input voltage: 3.7V ~ 8.0V Current: 900mA
3W Cree Drop-in Module (supports Surefire 6P)
http://www.dealextreme.com/details.dx/sku.6090
$10.14 3V~18V
Cree 5-Mode Emitter Reflector and Driver Module
http://www.dealextreme.com/details.dx/sku.4296
$14.80 Typical driving voltage: 3.7V (maximum voltage: 4.2V. Do not exceed.)
Cree Drop-in Module for Surefire 6P
http://www.dealextreme.com/details.dx/sku.6076
$10.00 Voltage Range: 2.9V ~ 9V
Cree Drop-in Module
http://www.dealextreme.com/details.dx/sku.7162 -
$12.48 Ultrafire 4-Mode 3.7V~6V
KLC8 LED Emitter with Driver and Reflector Module Set
http://www.dealextreme.com/details.dx/sku.8835
$9.90 (3.7V~6.5V Input)
Q5-WC 3-Mode 0~100% LED Drop-In Module
http://www.dealextreme.com/details.dx/sku.11074
$16.90 3-Mode: 0~100% (adjustable) > Strobe > SOS 3.7V
Review: http://www.light-reviews.com/dx_sku_11074/
Cree Q5 LED Drop-in Module
http://www.dealextreme.com/details.dx/sku.11621
$12.42 Input Voltage Range: 3.7V~18V Maximum Output: 200 Lumens
Cree Q5 LED 5-Mode Drop-in Module
http://www.dealextreme.com/details.dx/sku.11622
$13.55 3.6V~7.2V Input, Current and lumens are rated by the manufacturer
1. Low 25mA, 80LM
2. Mid 550mA, 120LM
3. High 950mA, 200LM
4. Strobe 800mA, 250LM
5. SOS 800mA, 200LM
Cree R2 Drop-In 1-Mode LED Module
http://www.dealextreme.com/details.dx/sku.11836
$12.40, Input: 3.7V~18V, Output: 117~225 Lumens (manufacturer rated)
Cree P4 1-Mode LED Drop-In Module
http://www.dealextreme.com/details.dx/sku.11810
$9.59 Input: 3V~12V
Cree Q2 LED Drop-In Module for WF-502B and Similar Flashlights
http://www.dealextreme.com/details.dx/sku.12501
$12.73, 3.6V~12V Input, Single mode regulated circuitry
Cree XR-E R2-WC 5-Mode 250-Lumen LED Drop-in
http://www.dealextreme.com/details.dx/sku.13658
$13.68 Input: 3.6V - 8.4V, Reflector: Textured, Memory: Unknown
Modes: High (250 lumens) > Mid (150 lumens) > low (80~100 lumens) > Strobe > SOS
Cree XR-E Q5 1-Mode Drop-in LED
http://www.dealextreme.com/details.dx/sku.13802
$11.80 Input: 3.7V - 12V, Textured aluminum reflector
Cree R2-WC 250-Lumen 5-Mode Memory Drop-in LED
http://www.dealextreme.com/details.dx/sku.14442
$12.90 - Input voltage range: 3.0V~8.4V - - Maximum brightness: 250 lumens (manufacturer rated)
5-Mode driver circuitry with mode memory: Hi > Mid > Lo > Strobe > SOS - Alumium textured/OP reflector
Cree R2-WC 3-Mode + 0~100% LED Drop-in
http://www.dealextreme.com/details.dx/sku.17593
$11.39, Input: 3.6V~8.4V, Cree XR-E R2-WC LED,
200 lumens (manufacturer rated), Aluminum textured reflector
__
** BugOutGearUSA **
http://www.bugoutgearusa.com/
*Premium* Cree Drop-In Module
$34.95 , 150 Lum, 4+ hours run time, 4.5V to 9V
http://www.bugoutgearusa.com/prcrdrmo.html
'Premium Plus' Cree drop-in
$39.95 , 170 Lum, 3+ hours run time, 4.5V to 9V
http://www.bugoutgearusa.com/cosoplcrmo.html
"Super Premium" Cree Q5 Drop-in
$49.95 230 Lum, 3+ hours run time, 4.5V to 9V
http://www.bugoutgearusa.com/crq5drmo.html
__
** Kaidomain **
Cree Q5 Drop-In 1-Mode LED Module
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1775
$11.53 Voltage Range: 3V~18V
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1769
$11.77 Voltage Range: 3.7V~18V, Output: 117~225 Lumens (manufacturer rated)
CREE XR-E P4, 6P Drop-in Module
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1634
$8.94 Voltage Range: 2.7V - 6V
Runtime:
About 1.7 hours on two 3.0V CR123A cells
About 2.5 hours on 17670 Li-ion cell
About 3.5 hours on 18650 Li-ion cell
K2 LED Drop-in (26mm)
http://www.kaidomain.com/ProductDetails.aspx?ProductId=4880
$6.90
** Malkoff Devices - http://www.malkoffdevices.com/shop2/ **
M60 Mod to fit Surefire
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=7
$55.00 - Input voltage 3.8V - 9V, Current Draw 750ma at 6 volts, Led is a Cree XRE 7090
Runtime is 1 1/2+ hours on 2 CR123 primary batteries, solid brass heatsink construction
Utilizes a Cree 8 degree optic.
M60F 20 Degree Flood
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=22
output is 220+ lumens, The optic produces an outstanding room lighting beam.
Throw is typically limited to approximately 120+/- feet. Utilizes a Cree 20 degree optic
M60L (Low Output)
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=8
$55.00 - Input voltage 3.8V - 9V, Current Draw 350ma at 6 volts, Led is a Cree XRE 7090
Runtime is 4 1/2+ hours on 2 CR123 primary batteries, solid brass heatsink construction
output is 140+/- lumens, Utilizes a Cree 8 degree optic
M60LF (Low output - Flood)
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=23
$55.00 - Input voltage 3.8V - 9V, Current Draw 350ma at 6 volts, Led is a Cree XRE 7090 Q5 WG tint
output is 140+/- lumens, The optic produces an outstanding room lighting beam.
Throw is typically limited to approximately 100+/- feet. Utilizes a Khatod 25 degree optic
M60LL (Low Low output)
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=9
$55.00 - Input voltage 3.8V - 9V, Current Draw 170ma at 6 volts, Led is a Cree XRE 7090
Runtime is 8 +/- hours on 2 CR123 primary batteries, solid brass heatsink construction
output is 80 +/- lumens, Utilizes a Cree 8 degree optic
M30 to fit a Surefire
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=29
$55.00 Input voltage is 1-5.5 volts, The output is approximately 235+ lumens at 3.3v+ and 160+ lumens at 3v.
The runtime is 1 1/4+ hours on one CR123 primary battery. The LED is a Cree XRE 7090.
This design utilizes a Cree 8 degree optic.
M30W (warm tint beam)
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=31
$55.00 The input voltage is 1-5.5 volts. The output is approximately 170 lumens at 3.3v+ and 120 lumens at 3v.
M60W (warm tint beam)
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=33
$55.00 The input voltage is 3.8 - 9 volts. Below 3.8 volts it will drop out of regulation and run direct drive.
The output is approximately 170 lumens. Runtime is 1 1/2+ hours on 2 CR123's. This design utilizes a Cree 8 degree optic.
M60WF (warm tint, flood)
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_8&products_id=35
The output is approximately 170 lumens. The runtime is 1 1/2+ hours on 2 CR123's. This design utilizes a Cree 20 degree optic.
__
** Wolf Eyes drop-ins **
Cree R2 WC LED Drop-in *Low VF*
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-147-6518
$63.99 - Limited Quantities
Voltage: 3.7V-13V, Output: 280 lumens
Cree R2 WC LED 2-Mode High & Low
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-147-6524
$68.99 - Limited Quantities
Voltage: 3.7V-6V, Output: 280 lumens
Cree R2 WC LED 2-Mode Tactical Strobe
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-147-6520
$69.99 - Limited Quantities
Cree R2 WC LED 4-Mode
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-147-6526
Circuit sequence: 100% (280 lumens), 20% and 2% for low, strobe.
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-147-6516
$59.99 - Limited Quantities
Note, this drop-in module is optimized to work best with a 3.7V LRB168A / 18650 Li-ion battery.
Cree Q5 LED *High Output*
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-125-6437
$57.99, Voltage: 3.7V-13V, Output: 260 lumens
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-125-6435
$54.00, Voltage: 3.7V-6V, Output: 260 lumens
Cree Q5 LED *2-Mode* (High & Low)
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-125-6494
$64.00, Voltage: 3.7v-6v, Output: 260 lumens (maximum stage)
Cree Q5 LED *2-Mode Tactical Strobe
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-125-6475
$67.99, Voltage: 3.7v-6v, Output: 260 lumens (maximum stage)
Cree Q5 LED *4-Mode
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-125-6496
Function: 3 brightness levels (Full, 20%, 2%)+ strobe
Cree Q2 LED *High Output*
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-148-6429
$44.99, Voltage: 3.7V-13V, Output: 190 lumens
Cree P4 LED
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-148-6283
$39.99, Voltage: 3.7-13v, Output: 130 lumens
Cree Q2 LED *4 mode*
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-148-6352
$49.99, Voltage: 3.7-6v, Output: 190 lumens (maximum stage)
Digital circuit sequence: 100% (190 lumens), 20%, 2% and Strobe (10Hz)
Cree Q2 LED 3.7-6V *High Output*
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-148-6415
$44.99, Voltage: 3.7V-6V, Output: 190 lumens
Cree LED 3.7-6V *2-Mode* (100% & Strobe)
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-148-6360
$49.99, Voltage: 3.7v-6v. Output: 190 lumens (maximum stage)
Q2 Cree LED *2-Mode* (High & Low)
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-148-6400
__
** Lighthound.com ** -
Lighthound Cree Drop-In
http://www.lighthound.com/index.asp?...OD&ProdID=2605
$29.99 accepted voltage: 3.7V ~ 9.0V 750mAh regulator board
Q5 Cree
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=3428
$39.99, 3.7V to 9V input, 750ma
UNIQ Cree Q5 Drop-In
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=3513
$29.99, 3.7 - 15V Input, 1000mA, Textured aluminum reflector
__
**Dereelight drop ins**1S(1-stage) cree XR-E module
$32.00
- Input Range: 2.8~4.2V
- Output Range: 1.2A
- Battery Type: 1x18650,1x17670
- Features: Constant output at it's fully input range
Over discharge protection
1SM-1(1-stage multi power) Cree XR-E Q5 module (6V max)
$26.50
- Input Range: 3~6V
- Output Range: 1A
- Battery Type: 1x18650,1x17670, 2xCR123A
- Features: Constant output at 3.8~6V.
1SM-2(1-stage multi power) Cree XR-E Q5 module (16V max)
$29.00
- Input Range: 3~16V
- Output Range: 1A
- Battery Type: 1x18650, CR123A's, RCR123's
- Features: Constant output at 4.5~16V. Recommended use 2xCR123A,3xCR123A or more.
3SD(3-stage digital) Cree XR-E Q5 module
$35.00
- Battery Type: 1x18650, 1x17670
Three stage output,100%-50%-5%
Memory functon
Change level by push switch
3SM(3-stage Muti-power digital) Cree XR-E module
$35.00
- Input Range: 3~9V
- Output Range: 1.0A
- Battery Type: 1x18650, 2xCR123A, 2xRCR123
- Features: Constant output using CR123's
Memory functon
3SD(3-stage digital) Cree XR-E 5A Q2 module
$36.00
- Emitter: Cree XR-E Neutral Warm White 5A Q2, it's highest rank at this tint, good color rendering, recommended for outdoor usage, especially after raining.
Memory functon
** OpticsHQ P60 Head and tailcap **
LED Drop-In and Multi-Function Tailcap Kit
http://www.opticshq.com/page/Optics/PROD/Surefire-HID/ACC-DTC-KIT
$89.99
Working voltage: 4.2-18.0v
Maximum output at the emitter approximately 220+ lumens about 2-3 hours
[FONT=Verdana,Arial,Helvetica][SIZE=-1]More than 6 hours at low output[/SIZE][/FONT]
Fits the following SureFire Lights: G2, G3, 6P, 6PD, 9P, Z2, G2Z, C2, C3, M2
LED Drop-In and Multi-Function (Reverse) Tailcap Kit
http://www.opticshq.com/page/Optics/PROD/Surefire-HID/ACC-DTC-R-KIT
$89.99
** Newexcite **
UltraFire Rebel Light Bulb with Reflector
http://www.newexcite.com/shop/index...id=126&zenid=682a08097b92cf4bb37a0e8d8065a820
$14.99 - (No voltage / output levels noted at this time)
* G & P *
G&P Q5 230 Lumens CREE LED Flashlight Torch Lamp GP751
$41.99 Input: 4.5v - 9v
G&P Q5 LONG FOCUS 230Lm CREE LED Flashlight Lamp GP751L
http://cgi.ebay.com/ws/eBayISAPI.dll...%3D4%26ps%3D42
http://cgi.ebay.com/G-P-Q5-CREE-LED...3251452QQcmdZViewItem?_trksid=p3286.m20.l1116
-=Surefire P60L LED Reflector Assembly=-
Max 80 lumens, Runtime up to 12 hours depending on flashlight model.
(stores listed in no particular order)
$39.00 - http://www.lapolicegear.com/sup6ledreas.html
$39.00 - http://supremeco.com.hk/catalog/product_info.php?cPath=1_26_30&products_id=4755
$39.00 - http://www.surefire.com/maxexp/main/co_disp/displ/carfnbr/254/prrfnbr/24502/P60L-LED-Assembly
** Assorted forum posts that you might find useful**
DealExtreme 1343, 1447, and Wolf-Eyes 130 Lumen Cree Module P60 Cree drop-in modules Runtimes!
REVIEW - CREE DROP IN from EBAY***VERY NICE***
Wolf Eyes cree drop-in
The post that started it Dealextreme drop in for G2, 6P, etc???
And many posts I probably missed.
Thanks everyone!
** Dealextreme **
$10.14 3V~18V
Cree Drop-in Module
1. Low 25mA, 80LM
2. Mid 550mA, 120LM
5. SOS 800mA, 200LM
$9.59 Input: 3V~12V
__
** BugOutGearUSA **
__
** Kaidomain **
Runtime:
$6.90
M60L (Low Output)
__
Cree Q5 LED *4-Mode
Cree P4 LED
__
Q5 Cree
__
$32.00
$26.50
- Input Range: 3~6V
- Output Range: 1A
$29.00
- Output Range: 1A
$35.00
Memory functon
$35.00
- Input Range: 3~9V
Memory functon
$36.00
Memory functon
$89.99
$89.99
** Newexcite **
* G & P *
Thanks everyone!
