Re: Need help finding my perfect P60 type led
@ionizedsky
The rule of 2 applies... Lumen brightness, run time, small size. You can have any TWO, to get all 3 something will need to be sacrificed.
So you are looking at around 90 minutes of run from a pair of RCR123 cells, enough lux+lumens to reach 100+ yards and light up a moderately large room. I can't think of any drop in that meet all these criteria.
A malkoff M60 will kind of do it, but you are only going to get ~45 minutes of run time. Same goes for a DX11836 or DX17593, and note that these are more spot-throwey than the M60. If you go this route my suggestion would be to carry backup cells to extend run times. Its not ideal but it will get you there. You could extend run times for any of these modules by switching to a 9P body and using 2x17500 cells, that should get you around an hour of regulated run time, or you could use a solarforce 1x18650 body + their 1x18650 extension. That would allow 2x18650 for really long run times.
If you need to retain th estock 6P size, a malkoff M30, or DX11074 will boost run times to about 1:30 (if you use a trustfire 2400mah cell). But you are going to have to mod your 6P for 1x18650 use. The fore-mentioned Solarforce 18650 body will do the trick.
