Raoul_Duke
Hi, I am having a 5 speed Incan regulator set up at the moment for a 6D maglite with a Five Mega 4" head and wondered if any of you has any suggestions on the drive levels for the 4509 lamp.
Its going to be switched straight onto high with no softstart, so dont want 100% to be too high :poof:
I hear that this had been driven of 4 li-ion cells ( 16.8V peak unloaded, and I guess about ~14.4V under load~), but not sure if it was softstarted or not ..... but most of the time mine would be run at one of the 4 lower levels......the lowest being whatever temp the halogen cycle can do its thing....If anybody knows what temp that is.....Cause I wouldn't know where to start on that...but trying to avoid a realy underdriven lamp....
So....... where would you space your voltage levels ( 1 low / 5 high & also initial turn on V)???
