tibim
Here's the story...
I was playing with my PD-S mizer tonight... switching back and forth between low and high a few times(by turning the bezel) and basically admiring the light... As I went to change from lo/hi (can't remember what it was on) again the light suddenly shut off. Pitch black. This battery had maybe an hour to two of runtime on it. The PD-S had definitely not started flickering yet(low batt warning).
In the darkness I turned the bezel all the way off and back on again, it lit up very faintly for probably 1/8 of a second, and then it shut off again. I took the bezel all the way off and put it back on, same thing... a slight flicker but it won't stay on.
I replaced the battery with a fresh one, and the light is normal again.
It's like the battery was instantaneously drained.
This is the second time this has happened. The first time I was using a battery station cell and I shrugged it off as being a crappy battery. This time it was a Surefire. There has to be something about the light causing this.
Is it possible that if something may be out of alignment/spec and causing a short circuit and instantly killing the battery?
I will get a voltage reading from the non-functioning battery tommorow.
I will also take a picture of the PD-S and its insides.
Any other suggestions?
-tibim
-tibim
