Penlight Comparison
Kiessling
Old World
Hi.
I have compiled a comparative review of the best three penlights I could find up to date. This review is specifically tailored to the needs of physicians with their daily use of those penlights and applies rather severe criteria.
The contestants are the following lights:
LedLenser Chipfire V16: a very slim light with 1 x 5 mm LED driven by 2 x BR435 lithium batteries. Tested for about one year in daily use.
read more about this light here
Penlux by Chief Wiggum: a custom-made light with a regulated Q3 LS using a trimmed-down Fraen optic. Drive current is 170mA, uses 2 x AAA batteries. Tested for three weeks now.
Here’s the Chief’s thread about his masterpiece: click !
Streamlight Stylus: 1 x 5mm LED driven by 3 x AAAA batteries. Tested for 2 months.
Further details of the lights will be discussed in the appropriate sections.
One point will be awarded if the specified criteria are fulfilled, zero points if the light is insufficient in that area. Bonus points are possible for extraordinary good performance.
A note about the Arc AAA that should work well in this field too, one might think. Well, it failed miserably /ubbthreads/images/graemlins/icon15.gif. It is too short and rides uncomfortably in the pocket, the knurling is too aggressive and makes handling difficult (you need two hands!) and destroys the other instruments in the pocket. One-handed activation is barely possible and the clip in combination with the rough knurling does not hold well to the light. In addition to that the knurling can make it very difficult to clean the light if ever covered with body fluids of any kind /ubbthreads/images/graemlins/icon15.gif. I tried that for about 3 weeks and abandoned the Arc quickly. That is why it is not included here, it simply dies not meet the criteria at all. /ubbthreads/images/graemlins/frown.gif
1. Construction and durability
Chipfire V16: Solid brass with powder coat finish. Stiff twisty switch, o-ring sealed. Recessed LED. I never experienced any problems with this one.
Penlux: Aluminium construction fully o-ring sealed with momentary pushbutton switch and twist action for constant on. No lockout possible. HAII finish. So far it works fine.
Stylus: Aluminium construction with momentary pushbutton and twisty for constant on as well as a possible lockout. Feels less solid than the other contenders, but did not fail me once. The LED is not recessed and might be damaged. HAII finish. More versatile but less sturdy than the competition.
2. Handling
Chipfire V16: Very slim and convenient carry, the clip works well for 1-handed operation. Activation of the light does not, you definitely need two hand for this. Bummer. Although there’s no knurling the finish provides a surprisingly good grip even when the hands are wet or bloody. A neat feature is a hole in the tailcap to mount a split ring or lanyard if desired.
Penlux: Carries just like a well-sized ball pen and rides comfortable in a shirt pocket. Clip works well and one handed drawing as well as putting it back is possible with ease. Activation of the light in momentary and constant on can also perfectly been done with one hand. Grip is exceptional because of a good knurling. This knurling is just about right … super grip without being rough or even destroying the other instruments in the pocket like the Arc AAA did. It is a pleasure to use this light!
Stylus: This one was a bit too large for my pocket and rode awkwardly, protruding more than any other instrument there. It never fell out though. One handed operation and drawing is ok, although it provides less grip than the Penlux.
3. Brightness
Chipfire V16: definitely on the dim side, but still sufficient to see everything you want without blinding the patient.
Penlux: very bright … you see everything and beyond … but a tad too bright for the eyes. Although I do not care about blinding someone with it since I am on the right side of the light, meaning behind it /ubbthreads/images/graemlins/grin.gif
Stylus: almost right, a bit too dim for deeper body cavities.
4. Beam quality
Chipfire V16: A very well defined beam without too much spill which is very good for looking into the patient’s eyes and testing the reaction of the pupils. Almost white.
Penlux: Square and even beam, almost pure white. The Chief points out a donut-hole but I think he is paranoid /ubbthreads/images/graemlins/tongue.gif … sidespill is almost non-existant which is very good for the above-mentioned reasons.
Stylus: Splotchy beam with lots of blue and huge sidespill and quite some backwash due to the protruding LED. Very disturbing.
5. Blood / vomit / spittle / urine and sh** resistance
Chipfire V16: No problems here, although the recessed LED is a bit difficult to clean when hit with armageddon. Never had any problems with some fluids entering the light.
Penlux: No problems either, dunked it in my toilet after I did my business there … just kidding /ubbthreads/images/graemlins/smile.gif. Cleaning is an easy job, no recesses on this light.
Stylus: Everything fine.
6. Batteries
Chipfire V16: Uses 2 x BR435 lithium tubular cells. Almost impossible to find.
Penlux: Uses 2 x AAA. Can have them for free in my hospital. Excellent.
Stylus: 3 x AAAA. Try to talk you management into buying some of those … /ubbthreads/images/graemlins/grin.gif
7. Runtime
The Chipfire lasted more than 4 months on one set of batteries, the Stylus should even last longer and the Penlux should be ok, too. I really did not want to do a test here, sorry. McGizmo will do this for me, I am quite sure /ubbthreads/images/graemlins/party.gif
points: 1 all lights
8. Regulation
This feature is desirable to be able to judge your patients always with the same amount of light, meaning you'd be able to eliminate one variable in the complex process of evaluating what you see in / on their body.
Chipfire V16: 0 points
Penlux: 1 point
Stylus: 0 points
9. Coolness factor
And yes, I admit it, this IS an important factor. I am a flashaholic after all.
Chipfire V16: very stylish and ultra-slim.
although quite a few people have one in my hospital right now … guess why /ubbthreads/images/graemlins/grin.gif
malus: -0,5
Penlux: no one will be able to have one like this! AND it is an excellent masterpiece!
Stylus: well, a clumsy stick that emits a bluish light, well …
although the shiny gold colour attracted some females …
bonus: 0,5
Conclusion
Chipfire V16: 5.75 points
Penlux: 9.75 points
Stylus: 5.25 points
That result pretty much describes what I could have said with many words, although your choice of light might differ according to your personal criteria, of course.
My choice is obviously the Penlux. The only annoying factor about this marvel is that I am living in constant fear it might be stolen … /ubbthreads/images/graemlins/frown.gif
bernhard
A nice review.
I am an optometrist. Spill light is a no-no for pupillary reflexes.
One hand operation is a must.
The Arc AAA has the drawbacks he mentioned which make it a bad choice.
My ophthalmologist son-in-law is also looking at this review.
Wonderful comparison, wish I could get one of the Penlux though, look to be a classic light, just what's needed from a carry standpoint. Any chance there will be some "extras" made?.
Al
John, the annoying spill is one of the main reasons why I finally terminated the use of the stylus and another negative point of the AAA I forgot to mention.
Al ... ask the Chief, I do not know if he would make more of them.
bernhard
Kiessling, that's a great review. That Penlux really performs! /ubbthreads/images/graemlins/grin.gif
Just out of curiosity, did you ever consider using an Inova X5? I'd imagine it might give you too much spill light, and it's not really a penlight, but still it might be useful.
both Inovas are too big to be carried appropriately and lack a clip which is a must in this application. The X5T is way too bright, too. It is not an easy task to find a high quality penlight. Fortunately the Chief has saved me /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/bowdown.gif
bernhard
I think the Stylus now comes with a glare guard as standard equipment...slips over the buisness end of the light and works quite well. I gave my doctor a Stylus as a gift, and he says he'd give up his stethoscope before he'd give up his Stylus!
PJD
yepp, you're right PJD. but this thing is as FUGLY as hell so that I threw it away as soon as I realized what it was /ubbthreads/images/graemlins/grin.gif. Not a very professional thing to do, but I knew I would never be able to walk around with something like this in my pocket.
bernhard
I got by for years with the "disposable" penlights, just developed a "come from the side" technique so as not to light the off eye. Shielding the nasal arch with an occluder also helped.
For other than pupil responses, the spill would be OK.
Strreamlight offers a black plastic sleve that goes over the led end of the Stylus that will reduse (to your requirements)the amount of side light.
Hey, thanks for the review Bernhard. I've been wondering how it's been doing for you.
The Penlux is a real pain to make. However, if you are a physician and need a good light, please PM me. I will consider making more for the folks in the field
I bought a Stylus for my wife (nurse), and she loves it. I don't disagree with your review; just that even the Stylus is a nicely done unit. Medicos that haven't seen one before go bonkers.
Roy, PJD mentioned this in his post above. My Stylus came with one but it was too FUGLY to bear /ubbthreads/images/graemlins/smile.gif
Chief, you are awesome. Nothing more to say about your offering, simply awesome. /ubbthreads/images/graemlins/bowdown.gif
And yes, my Penlux is doing fine. It is the one killer-penlight in our clinic everyone wants /ubbthreads/images/graemlins/tongue.gif
Phaser, of course the Stylus is a great light, as is the V16. These two were the best I could find in the market, they are top of the line and are only beaten by the Chief's creation. I was very happy with the V16 for about one year, and that says alot. The Stylus was no disappointment either.
bernhard
lol, everyone that seems my girlfriend's light wants one too. I just tell them I'm not accepting orders anymore /ubbthreads/images/graemlins/grin.gif
How's the anodizing holding up?
Chief, the Anodize is still perfect. No scratch or ding, although I am treating this light with respect and I do not let others use it /ubbthreads/images/graemlins/grin.gif
bernhard
P.S.: as imagestation has killed the pics I'll load them up on my new host ...
Tom, I only have experience with those el-cheapo penlights for a few bucks or for free using incan bulbs, and naturally I haven't been too impressed with them.
this one seems decent, although I doubt it could match the Chief's creation /ubbthreads/images/graemlins/grin.gif
Do you have one?
bernhard
Hello Bernhard,
I do not have one, but have thought about getting one.
It sounds like the Chief's light is going to be hard to beat.
I was wondering if a quality halogen bulb would be better for tissue analysis than an LED. It sounds like the LED's are doing fine.
Tom
