Hi All,
This is my first post on the Candlepowerforum. That being said, I've been reading around here for over a year.
It was this forum that taught me the meaning of Lumens, Lux, Chinese Lumens, protected & unprotected 18650's etc. So, I wanted to start with a thank you to all of you inspiring people out there.
Now, getting to business. I'm a huge Nao fan, but like the rest of you, I'm dissapointed by the battery pack design. What is the use of a 18650 powered headlamp, and a big-bag-o 18650's if you can't use them?
So, I tried a first mod which ended badly. My approach was to extract the PCB from the original Nao cell, and attach that to 18650 holder clips so a actual battery holder would not be needed. Result was not desirable.
Second try: I decided to change approach. Instead of changeable cells I decided to go for an external belt mounted battery pack which would allow the NAO to run all night (at least) on it's highest output setting.
For that, I bought the Nao extension cord and scrabled together four flat form factor 2200 mAh batteries and checked if they were still healthy.
Then, I glued them together, sealed the package with tent-repair kit fabric, and used Velcro + an 18650 sized lipstick to "interface" it with the Nao's battery holder.
Result:
It does not win prices for it's looks, but my initial run with this thing at my belt indicated that it should last at least a couple of hours more than the original battery.
My question to you guys is : Did any of you do any (successful) mods of different form factor battery's than single 18650? Am looking to improve this thing
