wquiles
Those ground inserts sure look sharp
WQuiles set up flood & he's never mentioned it being smelly/messy/etc. http://www.candlepowerforums.com/vb/showthread.php?364617... Now, I know I will not be using flood coolant on my lathe. My shop is small, not well ventilated and in the house... Flood coolant sounds too smelly and just too messy.
Most literature suggests that DOC should at least equal nose radius. Depending on edge treatment it's sometimes possible to run the DOC as small as 2/3 of nose radius & still get good chip breaking. Less than that & it gets iffy quickly.Apparently there is is a range of doc where the chip breaking doesn't work.
+1It is difficult to find an insert the does well in both aluminum and titanium. The .51 nose radius if is both extraordinarily sharp and quite delicate. I use that same insert for titanium finish cuts but limit depth of cut to not more than .25 mm. If you push it much harder than that tip life is quite short.
Yup. Not smelly at all. That TRIM MicroSol 585XT plus distilled water works wonders with Titanium. Now-a-days I use it for "all" metal cutting. The only time I run the lathe dry is for Delrin.WQuiles set up flood & he's never mentioned it being smelly/messy/etc. http://www.candlepowerforums.com/vb/showthread.php?364617
+1Titanium is best machined with flood unless you have an endless supply of inserts. Insert life machining Ti under the best of conditions (short & rigid setup, sharp fresh insert designed specifically for Ti, flood coolant at the correct mix, etc.) is much shorter than when machining most other materials. This isn't to say that Ti cannot be machined dry. Anything is possible.
Exactly what I have found as well. The best insert for Aluminum is a little too delicate but all but the lightest Titanium machining. Lately I have been using the Sanvik H13A inserts which are outstanding in Titanium, and pretty good for Aluminum.
I know I will not be using flood coolant on my lathe. My shop is small, not well ventilated and in the house... Flood coolant sounds too smelly and just too messy. So if I turn titanium I doubt I will ever take any kind of roughing cuts to avoid titanium fire. 0.25mm is 0.5mm in diameter reduction, that sounds plenty enough to me.
I have no experience about it obviously, just reading online it seems people usually stay away from coolant in a home shop because they don't want to worry about the coolant getting rancid, stinking (maybe it only smells after a while or gone rancid ?), having some rust issues (although I thought a coolant was specifically designed to NOT cause any rust), etc.WQuiles set up flood & he's never mentioned it being smelly/messy/etc. http://www.candlepowerforums.com/vb/showthread.php?364617
In that case I have definetely been too shy for my first chips making attempts!Most literature suggests that DOC should at least equal nose radius. Depending on edge treatment it's sometimes possible to run the DOC as small as 2/3 of nose radius & still get good chip breaking. Less than that & it gets iffy quickly.
Well if you have too many, I could get some of them off your hands and you could recoup part of your cost ?Yup, I scored a bunch of H13A inserts late last year, like 80 of them. At the rate I'm going with these they will literally last me a lifetime. But hey, at under $2 per insert, who can't pass that up! And that's including shipping. The other 100 inserts behind them were just over $3 per insert, shipped from Germany.
That leaves me with a question though. Say, I have a scratched OD flashlight body, and I just want to "touch up" the OD to refinish the shine. How would I do that if the smallest cut I'm supposed to take with my finish inserts is that much ? Sometimes there isn't much "meat" there. I need to experiment more DOC, feeds and speeds.
We never can be too carefull. I have a tooth brush to evacuate any annoying coil, so my hand/fingers never get too close to them while the lathe is running.Be REAL careful about that. Those cute springy curls can be razor sharp and strong as steel. They will cut you like a knife.
There are thousands of urban legends & the flood coolant legend goes hand in hand with "never use compressed air to clean a machine tool". It seems that many experts who make these statements have limited exposure operating machine tools. You have to remember when on the error-net to believe half of what you see & none of what you hear :nana:... reading online it seems people usually stay away from coolant in a home shop because they don't want to worry about the coolant getting rancid, stinking (maybe it only smells after a while or gone rancid ?), having some rust issues (although I thought a coolant was specifically designed to NOT cause any rust), etc.
I don't know anyone in any shop that does that.My machine will not see *that* much use. If I have to evacuate the coolant and dry the machine thoroughly after each use, that may be a PITA.
I don't know how other machinists work but I was taught from Day 1 to clean my machine at the end of the shift, wipe off the ways & apply a coat of Vactra #2 way oil. You will never ever have a rust issue if this is done every time the lathe is used.... very counter-intuitive to leave a machine "wet" before going to bed.
You "should" feel the crests somewhat. If you are using the machine to advance the cariage, you are basically threading, right?The finish I get on the pics is using the slowest feed available on the PM1236.
I can still see and feel with my fingernail the feed crests on the finish. As if it was a very very fine thread, sort of.
It is a combination of things, but you get the best finish when you use Al-specific inserts with a very sharp edge. What "exact" inserts you are using?What is the secret ?
I am using :
DCGT 32.51 AK H01 DCGT 11T304 AK C2 Uncoated Polished Turning Insert for Aluminum 10/pack
