Pila GL3 Review -- by: jtice (John Trotto)
jtice
West Virginia
This is a review of the GL3 Passaround light,
Made possible by JonSidney of www.jsburlys.com
Pila GL3
=== First Impressions:
The GL3 seems very well built, and ready for punishment.
The knurling is just slightly less agressive than Surefires, and feels good and sturdy in your hand.
The tailcap is a good bit larger diameter than the body of the light, making it easy to keep a grip on.
The light is alittle heavier than I would like. It reminds alot of the Pelican M6, in its overal shape and weight.
There are many places on the head and tailcap that have grooves, or fluted places. These add a nice look to the light.
These are also signs that the manufactor took the extra step required to make them. They cannot be made by a lathe alone.
=== Tail Switch:
I was quite impressed with the tailswitch.
It feels very solid, and has a good tactile feel to it.
It clicks solidly, and also works well in momentary use.
The tailcap can be unscrewed to provide the light with a lockout feature. Something very valuable when tossing the light
in a backpack.
=== LED Tail Switch:
I wasnt as impressed with the optional LED tailcaps.
They provide alot more versatility to the light, but overal, they make the light harder to use.
For one, you loose the clickie, you must twist the tailcap on all the way for constant on incan.
You tighten alittle for the LEDs.
The tactile feel was not near as good with the LED tail either.
My biggest complaint about the LED tailcap is, I kept blinding myself with it!
In normal use, most of the time, you have the tail end facing you. Ii would goto turn on the light, and the LED mode would
turn on momentarly before the incan mode kicked in.
The LED tailcap is also said to be not as water tight. It is only splash proof.
=== Light Output:
Well, this is what its all about right. /ubbthreads/images/graemlins/smile.gif
The first thing I noticed when I turned on the GL3 is, WOW this thing is bright!
The second thing I noticed was its color. It is surprisingly white for an incandesent light.
We arent talking HID white, but very white for your typical incan bulb.
You can actually fell a large amount of heat emitting from the front of the light.
I felt as if I could get a small tan if I left it close to my skin for a while.
The head itself would also heat up a good bit, but never to a level that was unconfortable to hold.
The beam has a rather large hotspot, fading nicely into the sidespill.
This makes the GL3 not the best thrower in the world, but it was excellent at lighting up an entire room, or side of a
house.
There were very little artifacts in the beam also.
The sputtered (orange peel) reflector did a great job of smoothing out the beam.
=== Runtime:
I didnt get a chance to do a good runtime test.
But, I was pleased with how long it ran.
One thing I noticed when using the rechargable Pila batteries was, the light would really only dim in the last 8 minutes
of its life, then simply go out altogether.
I was very impressed with this, as I cant stand lights that slowly dim over time.
I think this had alot to do with the batteries themselves, as they are designed to shutdown after a certain voltage.
=== PROS:
Very strong construction.
Good design.
Very bright, smooth, good colored beam.
Versitility of optional LED tailcaps.
=== CONS:
Alittle heavy.
Cannot stand on tail. (might be able to with LED tailcap, I forget)
LED tailcaps were not as user freindly.
=== CONCLUSION:
Overal, I really liked this light.
My biggest complaint was its weight. But that is only a side effect of its super strong construction.
This made an excellent light for lighting up an entire room or garage with light.
Sence getting into LED lights, I have not purchaced an incan light in months. The GL3 was by far, the best incan light I
have had the pleasure to use, so pleasureful, that I ended up buying a G3 (same as GL3, except no LED tailcap) off a
fellow CPF member.
=== Photos:
Pila GL3 Gallery
Fine review, Ticey! /ubbthreads/images/graemlins/thumbsup.gif
I like how you organized it by breaking it down into the major components, output and runtime and your impressions.
Britt
I've been a big fan of PILA for a while now.
Your review is very open and honest, as well as accurate.
very well done
Re: Pila GL3 Review -- by: jtice (John Trot
Great review! Very accurate indeed.
jtice, what light would you compare this to for output of the main lamp and led tail?
Phaser,
Hmmm, well, its the brightest incan I have,
It fills a room alot better than my Tec40, but, I think the Tec40 throws alittle better.
But, the GL3 had ALOT better looking beam. Alot less artifacts.
The LED tail? hmmm
Well the white one was quite dim, Jon says that was a bad one, that most are brighter.
The red one was quite bright, At least as bright as my white Inova X5T.
Hope that helped alittle.
jtice, thanks, it kinda does. Sounds like Pila used the same resistance possibly in the red and other color leds, so the red might be drawing more juice than you'd normally feed it. That might account for it being reported as the brightest.
Re: Pila GL3 Review added by TOB9595 w/ pic
Ticey summed up the particulars that I tend to agree with. Except the ease of using the led tailcap and incan one handed. I like it this way. /ubbthreads/images/graemlins/cool.gif Easy to manipulate and gives the best of both types of light.
I'll add my illuminating experiences with the Pila GL3 /ubbthreads/images/graemlins/smile.gif
This weighs 8.5 ounces and when I first got it I thought it too heavy. Now after edc'ing it for several days and using it heavily (pun);
It's not too heavy...It's just right.
Even tho my edc is a MrBulk Baby Pin. (luv it, luv it...)
I carried it with the GREEN led on the tail cap.
The green is very bright to my eyes. Brighter than what?? /ubbthreads/images/graemlins/confused.gif
Hmmmmm, Inretech aa green dropin, Arc ls green. That's about it for my green led exposure....
The white led was very dim and covered in Ticey's review.
I haven't tried the red yet.
I use this to alight instrumentation that if using the incan would blind me.
It's a well machined piece. Yet still rolls around. I would prefer the flats and flutes to be more pronounced to prevent rolling.
With the led tailcap the light will stand on end.
Run time for the incan is just less than one hour.
Charging time is ~1.5 hour
I'll compare this to a Streamlight and TigerLight tomorrow. As I think these lights are in the same arena as the Pila. Maybe I'm remembering wrongly? We'll see. /ubbthreads/images/graemlins/smile.gif
I thoroughly enjoyed the ease of using the double ended wonder. I had no problems with manipulating the light on with one hand due to the flats and knurling
Thanks so much for the opportunity to try this bad boy out.
/ubbthreads/images/graemlins/buttrock.gif
OH YEAH! The PIC!!
Tom
(knife is AG Russell, Loveless, Lone Wolf, City Folder. Slipjoint)
Nice review! Based on this, I ordered one from Jon.
Can't wait!
Rich
Re: Pila GL3 Review pics TOB9595
here are the comparison pics:
Distance was twelve feet to the row of flashlights /ubbthreads/images/graemlins/smile.gif
Lights Tested:
SL Sabrelight for giggles
Pila GL3
SL 20XP
TigerLight FBOP
I gotta say that this is a light, with the green led, that satisfied my every use.
Tom
Yep. that looks about right.
Its not a super thrower, but man is it good at lighting up a room. /ubbthreads/images/graemlins/smile.gif
If I hear a noise in my house at night, this is the light I will grab to search it out. /ubbthreads/images/graemlins/smile.gif
Great job Tom.
I finally got my hands on a gun cable switch and mounted mine on a Benelli Nova Tactical. Man it lights up a room or car interior when I point that thing at people
