Justintoxicated
Will this charger charge RCR2's the ones I have are the 4.2v kind. Also, where can I get a spacer to charge them if it is safe?
The specifications which I got from their website, says it's charge rate is 600mA. Thats probably too high for a CR2 Li-ion. Its recommended that you do not charge faster than 1.0C.
RCR2?
I read RCR123... Sorry, hazna is completely right, RCR2 mustn't be charged with the Pila, you need either one of the Nano-Chargers or the WF-138.
I got this charger when I bought my Tenergy RCR123 Li-on cells. It terminates about 4.12V for both channels.
The back of the charger says 360mA charge rate which is a whole lot safer for the smaller cells.
LOL..I hate when I forget to include the link!
Let's try this http://www.batteryjunction.com/smchforrc3li.html
That Tenergy charger looks exactly like my Soshine charger.
If I'm not mistaken, it's the same as Powerizer's, as well. Personally, I'm not too impressed with them. I have three that I bought some time ago with cells included, two 3.0 Volt LiCo's and one 3.6 Volt LiCo. They all work, but all but one of the 3 Volt chargers, fail to fully charge good cells. They also appear to trickle charge after completing the charge, not a good thing.:sigh:
Dave
My RCR123 cells are tenergy 3.0V versions but they charge right up to 4.1+V like my 18650 & 18500 AW cells. I think the 3.0 thing is a lie!
What I'd do Justintoxicated, is go ahead and get the Pila. It's a really good charger for 17500-18650 cells and RCR123's and 14500's in a pinch. Unfortunately, the Pila is, as has been mentioned, too high a rate for your RCR2's @600mA.
There really aren't any commonly available "good" chargers for RCR2's, short of getting a hobby charger. As much as I hate to recommend an UltraFire charger, I bought a WF-138 a while back for charging my LiFe RCR2's (with magnets), as it will work for them (3 Volt) as well as regular LiCo and LiMn cells (3.6 Volt) and has a 250mA rate, good for smaller cells. Sometimes these chargers are junk, sometimes you get lucky, as I guess I did, and they work quite well.
I find myself using the WF-138 for my 123's and 14250's, as well, at least untill I get my hobby charger figured out. It stops charging LiCo's at 4.19-4.20 Volts and LiFe's at around 3.6 Volts. I can't complain about that. It may trickle charge after completion, but I always watch my cells closely while charging, and pull them off when they're done anyway.
If you did get a WF-138, it opens up the possibility of using LiFe cells in the future. I find it superior to the DSD, nano's and all the other really crap chargers I've had. They aren't a real financial burden either, unless..... you get a bad one. I'm afraid that if I get the WF-138 and some rechargeable 123's I might never get the pila hah
Dave
