Hello Everyone,
Im not much of a battery guy, every once and a while (maybe every two years) I come out and replace my 18650 batteries. I tend to just buy the biggest capacity AW batteries available. My lights that I use regularly are a 1X18650 and a 2X18650 light which means I have three batteries I need to charge.
When I first got CPF'd I was told very early on that Pila made the best chargers. I have two PILA chargers now and like to leave 3 batteries in the lights and three in the charger so that I can just swap out when needed. My understanding (and please correct me if I am wrong) is that in MOST chargers this is NOT safe to do with an 18650, however using the Pila which has some kind of a trickle charger this is "mostly" safe to do? (I should clarify the batteries are seldom left on for more than 1 day).
Anyway, I have recently gotten a few more different lights that I use from time to time and I have some different battery configurations now. 18500, 16350, 18350, 17650. The problem is when I travel I have all of these spacers to bring. Plus I have to bring two chargers, which means two wall-wart plugs, 2 12 volt DC plugs, etc etc.
Right... so I discovered the above mentioned i4 v2 charger. I noticed that it is also MicroProcessor Controlled... this would allow me to charge 4 cells independently. I have also seen in mentioned that this trickle charges as well. Would this be a good option or should I stick to the Pila?
Thanks,
Stephen
Thanks,
Stephen
