Polish scratches from polycarbonate lens?
mbirds
Virginia
Hi,
I have a Barbolight U-04. For durability it has a polycarbonate lens (is that lexan?). Mine has seen rough use on many dives and has some scratches on the lens. Is there any way to polish them off? I have a dremel with buffing attachments but I really don't want to screw up this light... any thoughts? I don't really care about artifacts but am more concerned with output. If the scratches don't affect output that much then I'll probably leave as-is unless there is a simple solution.
Thanks!
Do a search for "toothpaste". You will find a heap of references to using it to polish scratchs from the plastic lens on surefire G2s. Sounds odd but apparently works well.
Home Depot sells a liquid Lexan Polish which seems to make the lens more transparent. It's in bottle about 12oz and is next to the display of DIY plastic (acrylic) sheeting.
Displex, it works fantastic. I have used it on everything from cell phones
to watches. It has taken out all my scratches 100%, even deep ones.
You can get it on eBay or the internet.
This looks similar to polywatch that lskov suggested.
Be VERY careful if you use it with a dremel.
This will cut very very fast and can cloud up the lens and ruin it
due to too much heat from the buffing wheel. I have had this happen.
The best and fool proof way is to do it by hand.
Also no one here has said that you will remove the AR coating
with these products if there is one on the lens.
Most flashlights lenses have AR coatings.
Thanks for all the info. Does an AR coating do anything underwater (I don't know if it even has one). I will avoid the dremel for sure and do this by hand.
TJZ: I don't know of any polycarbonate lens with AR coating... Usualy that is glass lenses... Besides AR coating on the INSIDE is what matters the most (as it helps light get out of the lens and not reflect back).
I would put some tape or putty around the bezel to keep the polishing compound away from the bezel, so you don't get the white residue in the cracks/etc by the bezel.
I'll do you one better than polishing compound.
There is this REALLY fine 3M sandcloth. They come in different colors and polish arcylic watch crystals no problem. Only problem is REALLY hard to find
I figured they did just like many flashlights with a glass lens do
like Fenix and so on...
Eyeglasses that are made of polycarbonate are what I'm thinking of.
I don't see why anyone wouldn’t put it on a polycarbonate lens flashlight.
This lets more light through the lens from what I read on CPF.
TJZ, ah yeah eyeglasses. But I don't know of any plastic lenses in flashlights with AR coating. My guess is if you want AR you want glass too, so they don't bother.
IsaacHayes, Thanks for the information. I now know more about
plastic lenses in flashlights, AR coatings are not used for them.
Maybe the AR coating is not that big of a deal. Sellers tend to
make you think so...
They sure work great on glasses though.
First, always practice on a test piece pf plastic.
Now, try, Brasso and/or silvo. Use a polishing cloth or makeup removal pads, and expect to work a little while.
THis works well, and can help remove or lessen big scratches (but you will still have light swirls in the lense).
This is a known trick for fixing up scratched iPods (polycarbonate face).
Thanks guys. I tried toothpaste, then brasso since I have both in the house. The toothpase seemed a little rough, but the brasso worked well. I didn't spend too much time but it was already making a difference. I was using q-tips. I figure I'll give it the full treatment after my big dive trip in March.
Another +1 for displex half the price of polywatch here in Australia.
Norm
We are using Makrolon GP, a polycarbonate by Bayer, with a scratch resistant finish. Probably one of the best! It is 5 mm thick, and it is difficult to replace the lens whitout some skills, but if yours is scratched we can send you one and instructions.
Contact me at id(at)barbolight(.)com.
Regards
