POLL: Your E2DL vs. LX2 Output - Share Your Personal Observation
How does your new LX2 compare to your E2DL?
  • Output appears the same
    Votes: 7 23.3%
  • LX2 appears a tad brighter
    Votes: 7 23.3%
  • LX2 appears noticeably brighter
    Votes: 8 26.7%
  • LX2 appears significantly brighter
    Votes: 3 10.0%
  • E2DL appears a tad brighter
    Votes: 4 13.3%
  • E2DL appears noticeably brighter
    Votes: 1 3.3%
  • E2DL appears significantly brighter
    Votes: 0 0.0%
  • Total voters
    30
bullfrog
AZ
Plain and simple:
From your personal observations, how does your LX2's 200 lumens compare to your E2DL's 120 lumens?
Obviously, this poll is for those who own both the E2DL and LX2.
Please no bickering about Surefire's marketing - this is purely to see the numbers and not to hate on or profess your love for Surefire :tinfoil: :D
:popcorn::popcorn::popcorn::popcorn::popcorn:
Both are very bright but by a very small margin the E2DL beats out my LX2 but like I said not by much.
I have 3 E2DL's and my LX2 is brighter than all of them.
I just picked up one E2DL that was said to measure 217 lumens in a I.S.
My LX2 is a tad brighter than that one and noticeably brighter than the other 2. :devil:
My LX2 is much more brighter than my E2DL. I'd say around 80 lumens more.:whistle:
Woohoo - zero reports of the LX2 being equal to the E2DL!
Way to go Surefire :party:
I really had to compromise my vote (noticeably). I have three E2DL's and a V-TAC L4 (basically a single stage E2DL). It is a tad brighter than my brightest E2DL and that one is easily in the M60 or Olight M20 class (240+ lumen) and it is noticeably brighter than my middle E2DL and V-Tac L4 (which are even) and I would rate that pair in the 200 -210 lumen range and it is a lot brighter than my oldest E2DL which is probably in the 180-190 lumen range. Based on other lights and their known outputs, my LX2 is easily in the 250+ lumen range and is my brightest small light. I've gotta go to a big reflector like a M30 or a MRV or a DBS to outclass this LX2. :devil:
My LX2 is definitely noticably brighter than my E2DL.
I wont say significantly, as I would only say that about my Olight M30 compared to my LX2.
:twothumbs
i know this is now an old thread, but surefire have changed the output of the e2dl to 200 lumens, does anybody have this model and how does this compare to the lx2 ?
ant
To me, the LX2 has a less defined but ever so slightly larger hotspot than the E2DL. They both have marginal spill (I'm a big McGizmo Haiku XPG fan) and rings at the periphery. The E2DL's hotspot MAY be a tad brighter, but when I swapped the LX2 head onto the E2DL body, I thought it was a tad brighter; it's probably not a detectable difference with the human eye. The E2DL head on the LX2 body results in a correctly functioning 5 lumen/200 lumen E2DL head with the LX2 UI: 5 lumen low first (lower than the LX2), then high. The LX2 head on the E2DL body will only run on high. You cannot fast click and get the low to come on. I prefer the lower low of the E2DL and will probably keep the E2DL head on the LX2 body.
BTW, I measured the tailcap resistance of the LX2 1st stage at 9.6 ohms.
Tailcap amp draws with fresh PRIMARY Surefire 123's:
E2DL (200/5 lumen model bought 2 months ago) 800 mA high 32 mA low
LX2 (200/15 Lumen model bought 1 week ago) 830 mA high 32 mA low which is 5.21 watts battery draw on high.
Both will run a bit dimmer on a single Li-ion source (4.2 volts); at this reduced level both lights have the same output and I cannot distinguish between the two.
Both run with 2x CR123A (AW brand rechargeable) with no stuttering or problems at all. They seem to be a bit brighter on the rechargeables; I compared the LX2 on RCR to the E2DL on primaries and the LX2 was noticeably brighter. Since they look equally bright when they're both running the same battery type, I take this to mean the lights are brighter on rechargeables.
Tailcap draw on 2 x RCR123A RECHARGEABLES (8.32 volts tested):
LX2: 530 mA High for 4.41 watts battery draw.
Tailcap draw on 1x RCR123A RECHARGEABLE (4.20 volts tested):
LX2: 515 mA High for 2.16 watts battery draw.
The LX2 and the E2DL will not light with a single fresh primary 123A cell.
The E2DL WILL fit an AW 17670 cell with the silver decal removed. The LX2 refuses to fit the cell under any circumstances.
It's very interesting to me that the higher rechargeable voltages result in less power being drawn from the batteries but the output is at least the same if not brighter. I don't have a means to test current or voltage at the LED; only the battery side and that should only be taken on a relative basis given my Fluke 179's leads have 0.4 ohms of resistance.
My last observation is that the low level of both seems to result in the same power being sucked from the batteries. Since the LX2 has 15 lumens versus the 5 lumens of the E2DL, and appears to be least twice as bright, the LX2 seems to be the winner in that regard- free lumens. Surefire rates the low runtime of the E2DL as 76 hours versus the 47 hours of the LX2, but as I've shown, the amp draws appear to be the same and runtime should be identical. I'm going to put fresh primaries in both and turn them on low and find out what happens.
