Casebrius
What do people use to pot their LEDs? I'm looking for something similar to the black stuff you see in Malkoff Pills. Thanks
And me tooWhat do people use to pot their LEDs? I'm looking for something similar to the black stuff you see in Malkoff Pills. Thanks
MG Chemicals Thermally Conductive Epoxy. Used it for years. Be sure to stir the crap out of each bottle before use because the solids drop to the bottom.
http://www.mouser.com/Search/ProductDetail.aspx?qs=nnh8/A0SuH/LBKx/KG5/kw==
I have generic epoxy I get by the quart. When heat really isn't an issue, but I don't want prying eyes seeing the electroincs, I put black dye in it and do the potting. If it's warm, I'll put it under a fan and/or do multiple pours so it doesn't go China Syndrome. Epoxy curing is an exothermic process, and if you try to cure too much in a confined space (like you do when potting), it can get ugly. The MG Chemicals listed above kicks off very slowly and tends not to heat up. In fact, I usually add heat.
