GCBStokes
Princeton Tec Apex NiMH Rechargeable AA Battery Runtime Test
I have been very please with the runtime I've been getting from my NiMH Rechargeable AA Batteries in my Princeton Tec Apex Headlamps. These are the ones I really like a lot, and two (2) of them stand out from the rest by a significant margin. I did my runtime testing with 14 different brands of NiMH AA Batteries.
For my runtime tests I use one of my Princeton Tec Apex Headlamps (Stock/None Modified) for each of the test. I ran the runtime test with each set of batteries three (3) times and selected the high end runtime of the three tests as my recorded runtime. Each test was conducted with the Apex set on the high 3 watt mode. I use a digital timer and concluded the runtime test when the Apex Low Battery Power Flash Started. I was told by Princeton Tec that the Low Battery Power Flash signals when the headlamp falls out of regulation.
(1) Sanyo 2700 mAh NiMH AA's - 4 hours 22 minutes 17 seconds
(2) Powerex 2700 mAh NiMH AA's - 4 hours 21 minutes 36 seconds
(3) Titanium 2700 mAh NiMH AA's - 3 hours 52 minutes 47 seconds
(4) Sanyo 2500 mAh NiMH AA's - 3 hours 36 minutes 21 seconds
(5) Titanium 2600 mAh NiMH AA's - 3 hours 35 minutes 52 seconds
(6) Energizer 2500 mAh NiMH AA's - 3 hours 28 minutes 32 seconds
(7) Titanium 2400 mAh NiMH AA's - 3 hours 27 minutes 28 seconds
(8) Titanium 2100 mAh (Low Self-Discharge) NiMH AA's - 3 hours 14 minutes 53 Seconds
(9) Sanyo Eneloop 2000 mAh (Low Self-Discharge) AA's - 3 hours 07 minutes 28 Seconds
(10) Rayovac Hybrid (Low Self-Discharge) NiMH AA's - 3 hours 07 minutes 21 seconds
Note: Even though I did test these other batteries that ran better then the Tenergy 2600 AA's, I would like to mention the Tenergy 2600 NiMH AA's. They run for just over 3 hours in my Apex Headlamp, and they cost under $6.00 per set of four (4) from BatteryJunction.com. Also note that the Sanyo 2500 mAh AA's got my #3 spot, but the Titanium 2600 mAh AA's actually run better on two of my 3 tests, they just had the lower low-runtime. Me personally if I had to pick between the Titanium 2600 and the Sanyo 2500 batteries, I would go with the Titanium 2600. I'm very impressed with all of the Titanium NiMH Batteries. The Titanium 2700's are very good batteries and if they follow in the footsteps of the Titanium 2400 & 2600 Batteries, they will last a very long time giving many, many charge cycles over the years. I have some that are 2 and 3 years old have have been charged hundreds of times and they still perform great! But as of now, when it comes to runtime in my Apex Headlamp the Sanyo 2700 AA's are champs with the Powerex 2700 AA's coming in a close second. With these two batteries you can expect over 4 hours and 15 minutes of regulated runtime! With runtimes like that, I find no need to use lithium AA's other then for cold weather performance during the coldest days of January and February in my Apex Headlamps.
Note: I understand that runtime with different Apex Headlamps and different sets of the same brand and capacity AA NiMH Batteries will differ slighty. However, in use in my Princeton Tec Apex, this is the order they finish in. And I hope all can use my Apex runtime tests to get a good gernal idea of how these batteries will perform in their Apex Headlamps.
And A Special Note: I would like to thank Tom (SilverFox) for his help and giving me tips and the how-to's of battery care, matching and charging tips using my Maha C-9000 Chargers. I still have much to learn, but he's gotten me started down the right path and on my way. I have come to know him as the "Godfather Of The Candlepowerforums."
