Confederate
- Joined
- Jun 22, 2006
- Messages
- 360
It's a AAA aluminum flashlight that has a red laser in the center, UV LEDs surrounding it, and regular white LEDS surrounding those. The light is supposed to switch between the three with a single button on the side of the light.
PROBLEM: The light works when I screw in the tail partially, but I have to hold it just so. If I screw it in all the way, nothing works.
Three AAA batteries fit inside of a cartridge that's inserted into the battery tube. The + side is down with a spring - connector/retainer at the top.
QUESTION: What is likely to be causing the connection problems resulting in the light's not working and how could I fix it?
Thanks!
Thanks!
