IsaacHayes
Boost. used for:
battery voltage is lower than needed for the LED to pull your desired current. Vin < Vf.
Buck: Battery voltage is higher than led Vf.
boost-buck: used when you have multiple battery voltages (primary and recharable) or the battery voltage is very close to the Vf of the led. Like starting it it's too high, then partially drained it's too low. The circuit keeps it at the right level to the led the whole time.
FluPIC is used with a higher voltage in than Vf, and IIRC it's not as efficeint as buck (which converts extra voltage into current, thus drawing less from the batteries than the led actually sees.). I believe it's called LDO which is kind of like a varible resitor if I'm correct in that it just turns extra voltage into heat inside itself.
