Pull optic out of dead Malkoff M30?
Bullzeyebill
CA
Awhile back I destroyed my M30 circuit putting a battery in backward, the old reverse polarity problem. I was wondering if I can remove the optic, and if so what would be the safest way?
Bill
Thanks for advise, but I talked to Gene a few months ago when it happened, and there was nothing to be done, it is not fixable. It was my fault, I knew that it did not have reverse polarity protection, so I just ordered another one. I want to remove the optic of the ruined M30, and see if I can fit it in one of my Cree Q5 lights, switch out a reflector for the optic.
Bill
If you cut the three retainers off of the holder the optic will come out, but the optic's basically impossible to use without the holder. The optics aren't that expensive.
I took apart a dead one. It was easy. There's one tiny spot of epoxy holding it in place. I used a knife blade.
Thanks LukeA and donn.
donn, the holder came out ok, so the holder and optic will work together?
Bill
BUMP to an old thread...
How well does the 8 degree Khatod optic work with an XPG? Anyone tried?
thanks!!:grin2:
