HarryN
Hi Jim (JS)
Thanks for the corrections on the tape and drive current capacity of Ni based cells. Hmmm - with 10 - 20 amp capability, maybe I should have purchased 100 watt power supplies instead of 30s. /ubbthreads/images/graemlins/smile.gif I guess that is what upgrades are for.
I mostly use Li based primary cells, and there is a lot of use of R - Li based cells in the LED lights, so I am sensitized to them, although, not entirely comfortable with them. Since the use of Li primary cells is rather expensive when used in high powered lights, I picked these supplies to allow for a wide Vin range, and a wide choice of cell types.
Certainly, the Li cells are well known for warming up from internal resistance heating long before the Ni based cells do. Ginsing has mentioned in various threads about cells getting "quite warm" after use, as well as some problems with cells splitting over time / cycling. You are correct that I speculated that this might be a heat issue.
I am probably overly sensitive to the insta flash issue because when I insta flash LEDs, the replacement is perhaps a bit more of an issue. There is of course the price aspect as well as the usually more complex installtion. Perhaps even more important is that LED guys are always trying to push the envelope on obtaining premium binned LEDs. These are often so rare it take a combination of time, patience, money, and connections with Guido to get some. I sold some WXOT binned Lux Vs last fall (from a group buy) thinking that by now, this would be a common bin. These are still relatively rare - certainly not off the shelf, and my supply of premium Lux IIIs is approaching time to refill.
I have not yet built up the tolerance to parts failure / wearout, so perhaps this is part of the thick skin that one develops working in the high power incan world.
Thanks for the info and guidance.
