I often see advice given that a relay harness or wiring upgrade is beneficial, this I certainly do not doubt, just questioning if it's possible to have them work with modern "CANBUS" equipped cars.
Specifically these newer cars that use pulse width modulation techniques to keep excess alternator voltages down for longer bulb life.
I've certainly heard that the E90 BMW 3 series employs this technolgy as well as some newer GM models, even for their headlights.
Just wondered how widespread the use of PWM is. I've heard it used for other lighting functions before, in fact my own car seems to use it for stop/tail light functions from a single 21W bulb.
So, is it now common for PWM to be used in the powering of main automotive forward lighting and the advantages of increased bulb life and DRL functionality must only come at the cost of a reduction in lumens?
If one had such a car would this techonolgy mean relay harnesses cannot easily be installed as the car would detect this and throw an error code/disable the output?
I seem to remember reading that for BMW 1 series and newer, once the bulb check warning for a particular circuit has been issued a certain number of times that output is permanently disabled and a new light contol unit is then needed.
