Check to see that the switch module is contacting the bare aluminum in the switch housing. That's what killed mine till I found it. Does the switch go "CLICK"? If not then it's time to switch out the switch. If it does then it's likely a contact issue. Mine was intermittent based on temperature. The cooler it got, the less likely the switch was to work till I bent the wire out a bit and re-installed the switch.
