Re: What exactly is \"throw,\" who knows?
Contrast is important. In designing Avionics type displays, a person tries to increase the contrast. This can be done by putting out more light, or making the blacks blacker, or doing both. This gives you more contrast between white and black and makes the display much easier to read in direct sunlight. Also, a person can reduce reflections off a display surface, to reduce the reflected ambient light (or reflection of the sun), which mainly affects how black, blacks look in relation to the whites. You can also scatter the direct reflected light with a etched or rough surface. Index matching various parts within the display and also matching the display surface to the surrounding air, helps alot. Typically Magnesium Fluoride and Silicon Dioxide are used in multi-layer applications, and is commonly known as Anti-Reflection coatings, such are found on the nice flashlight lenses you buy from flashlightlens.com. This also increases transmitance, and can amount up to 8% gain in transmittance, and a easy 5x to 10x reduction in reflections.
One trick that was used with EL panels was to put a circular polarizer in front of the display. This prevents metallic parts from being seen from the outside, in bright light, since the polarization is opposite and doesn't make it's way back out.
Now, mentioning this, I've been surprised to not have seen any mention of circular polarizers or linear polarizers over a flashlight, and also the same in a set of vision glasses. This would help a fella to enhance or reduce glare off certain objects, and enhance the apparent contrast to the human eye.
You can go a bit further and start thinking about contrast between colors, and the peak wavelengths the human eye can see, or attack it by using shorter wavelength blue and longer red wavelengths. As soon as you start seeing light from true tri-band sources, say R, G, B bands, it's amazing how alot of things almost reach out and touch you.
You can get a little deeper, looking at the population of cones in the eye, and the distribution of R, G, B, as it changes, and is reflected in the CIE curves for a 2 degree and 10 degree observer. The target size actually makes a difference for seeing color.
There are lots of little neat tricks a fella can utilize to pull certain types of things out of a scene, that are within the grasp of the hobbyist....
