Quark RGB
computernut
Canada, eh?
I understand the Quark RGB comes with a reverse-clicky. Can you change the tailcap for one of their tactical forward-clickies? I searched around but didn't find anything conclusive.
Thanks.
Yes. Just remember the UI doesn't change, so to switch modes you'll be doing something like tap-tap-click instead of click-tap-tap.
The only thing you will lose is the ability to tail stand, which is essential to me, but may not be to you.:twothumbs
Yeah, that tailcap is pretty sweet. I just wish 4sevens would consider putting out an RGB that had the preon UI. That would probably make my RGB my favorite light . . . I love floody lights!
Yes, it does work, but . . .
I ordered an RGB plus forward clicky switch for exactly this reason. The forward clicky does work, but unfortunately it frequently skips modes. I think there must be something in the forward clicky switching that makes the light engine think that you've clicked more than once.
Even without this problem, momentary action is out of the question anyway because of the very long four-second delay for mode-changing.
It was so infuriating on mine that I had to go back to the reverse clicky.
+100 jblackwood - you've hit the nail on the head there: Preon UI would be sweet.
I'd like to see something more like the a fusion of the Maelstrom and Tactical UIs: 4 position control ring for output color, and two programmable modes per color accessed via the bezel in tightened and loosened positions.
I think that would be really intuitive if they could do that(since there are 4 colors). If they would come up with a UI that worked a bit like you just mentioned, I wouldn't hesitate to pick one up. Although I don't think the current UI is all that bad.
