CobraMagnum
- Joined
- Oct 17, 2018
- Messages
- 8
Hello, everyone. I'll make this brief. Before I begin, I have two separate questions and, if possible, I would be appreciatie if someone would take time to answer each. Thanks in advance.
More than three years ago, I purchased a Maglite ML50L 611 Lumen LED flashlight, which requires 3 C-cell batteries. The light has seen moderate use, and it is primarily used on the medium and eco modes (at least recently).
Although the light functions very well and is in excellent condition from what I can tell, the last two times that I've had to replace the batteries, which I am estimating were about 6 months apart (between the first time and the second time), it seemed like I didn't receive anywhere near the runtime which is advertised for this light, which is 16 hours on high mode. Although it could be a misinterpretation of how long I've been using it, I don't think either time that I received even close to 16 hours of accumulated runtime.
Question 1) Could my Maglite be experiencing a parasitic drain issue, and if so, would that be causing sooner-than-expected battery replacement?
Question 2) When the Maglite is not in use, does it help to unscrew the tailcap, and if so, should I even take the batteries out of it completely? Or just unscrew the cap?
Hope you all have an excellent day!
