shakeylegs
I'm using 4 of AW's 14500's in a modamag 4-by serial holder as a power source for a 1D 5 Cree setup. The setup worked for a short period then exhibited some ghostly behavior and stopped functioning. I measured the pack at 15+ volts a few days ago after the light crashed. Thought I was having problems with the switch which was moded for a maxflex. Switch tested fine. Everything wired properly. Then I checked the emitter connections and found two had worked loose. Resoldered them and fired up the light. Nothing. So I checked the battery pack tonight and it was exhausted. One of the 14500's measured 3.26 volts, another 2.6 volts. The other two showed 0 volts. I'm guessing there was a short that caused the rapid drain.
Question. Are those two "0" batteries drained completely or have they simply fallen below the protection circuit voltage minimum? Secondly, why would two batteries drain so completely while the other two maintain energy? Finally, should I retire the two depleted batteries or at least not pair them with the other two? I'm wondering about any safety issues. These are almost new, low use batteries.
