Recommendations for a 14500 LiIon programmable, 2 independent bay charger
BVH
CentCalCoast
I'd like a small, plug-in or USB powered, quality, 2 independent bay charger for 14500 Lithium batteries. The capability to charge large cylindrical cells is OK. I want to be able to program the charge rate and termination Voltage. I have the MCA 3000 but it's way too big, complicated and overkill. Something that I can set a charge rate and termination Voltage and never have to change it again until I get a different EDC light. Just plug and go. Does it exist?
This means that most simple chargers are already completely overwhelmed with this.
It's worth using one memory on the MC3000 for an EDC lamp.
Especially with EDC lamps, there are certain requirements when it comes to charging speed and final voltage.
For example, memory number 20 is reserved for mine. And as long as I don't need the 4th slot for other batteries, it's usually set up for that (as an example).
